Home > Technical > Auto Lights Problem???
BIG DJ
Anyone ever had these go up the spout? Driving back from Carlisle today and noticed the headlights where on. Weather was fine and nice sunshine so no reason to be on. It's like the sensor has gone!!
Anyone experienced this before?
Post #280326 Mon Nov 15 2010 7:07pm
DSL
Weird or what, had exactly the same on road up the M6 & M74 past Carlisle & up to Abingdon on Saturday!!! Switched to OFF & used ON when started to get dark, though switched to Auto to check working and they were. Shocked
Post #280328 Mon Nov 15 2010 7:29pm
BIG DJ
Very strange. Turned off and back on but still on. Haven't tried after car turned off yet as it was dark by the time I got in. Will try again tomorrow and see if it's reset.
Post #280329 Mon Nov 15 2010 7:38pm
Bradders
Happens to me every now and again. They often stay on when exiting a tunnel for example even in bright daylight. I just ignore it now. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #280331 Mon Nov 15 2010 7:44pm
DSL
They do switch they lights on when very low light angle but bright, maybe gets confused. Hey they are LRs, we're not meant to understand. Whistle Mr. Green
Post #280334 Mon Nov 15 2010 7:48pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Same with me today Exclamation
Wondered if with all the ice etc salt residue and other muck was covering a sensor making it appear darker than it actuallly was
Post #280335 Mon Nov 15 2010 7:57pm
BIG DJ
Least it's not just me.
Anyone know where the sensor is? Maybe as said it's covered with muck! It definatly wasn't dark enough to stay on.
Post #280336 Mon Nov 15 2010 8:19pm
DSL
If same as on D3 (a RRS being a D3 in drag) there are sensors in the rear view mirror looking through windscreen. Will give mine a clean tomorrow once it's got above freezing. Sad
Post #280337 Mon Nov 15 2010 8:23pm
BIG DJ
Thanks DSL Thumbs Up
Will see if they still come on tomorrow and if so give the area a clean and see what happens. Will update the thread accordingly Thumbs Up
Post #280338 Mon Nov 15 2010 8:32pm
Bobby
Quote:
AUTOMATIC HEADLAMP OPERATION
The automatic headlamp function is a driver assistance system. The driver can override the system operation by selection of side lamp or headlamp on if the ambient light conditions require front and rear lighting to be active. The automatic headlamp system uses a light sensor and the CJB, which are connected via the LIN bus to control the headlamp functionality.
A light sensor is incorporated in the rain/light sensor located on the inside of the windshield, below the rear view mirror. The wiper system also uses the rain/light sensor for automatic wiper operation.
The light sensor measures the ambient light around the vehicle in a vertical direction and also the angular light level from the front of the vehicle. The rain/light sensor uses vehicle speed signals, wiper switch position and the park position of the front wipers to control the system.
The automatic headlamp operation uses ambient light levels which are monitored by photodiode incorporated in the rain/light sensor. The rain/light sensor sends a lights on/off request to the CJB on the LIN bus, which responds by switching on the low beam headlamps, front side lamps and rear tail lamps.
The automatic headlamps are activated under the following conditions:
Twilight
Darkness
Rain
Snow
Tunnels
Underground or multistoried car parks.
Operation of the automatic headlamps requires the ignition switch to be in position II, the lighting control switch to be in the 'AUTO' position and a lights on request signal from the light sensor. If the rain sensor signal activates the wipers fast speed wipers, the low beam headlamps are activated, providing the lighting control switch is in the 'AUTO' position.
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #280342 Mon Nov 15 2010 10:12pm
DSL
On Sat would have added early afternoon sunshine with the odd cloud to that list. Was deffo on when it should have been off. Confused
Post #280343 Mon Nov 15 2010 10:18pm
BIG DJ
Same with mine early afternoon, sunshine and definatly not dark enough for them to be on. Wonder how many other people this has happened to and they haven't even realised due to it not being that easy to see that they on in the day via the dash.
Post #280357 Tue Nov 16 2010 7:22am
DSL
I've got aux lights so when on I get an orange light on the switch when lights are on. From my07 the D3s have a green light in the dash to say they are on, don't know about RRSs.
Post #280360 Tue Nov 16 2010 8:42am
BIG DJ
Probably the same. I've probably just never noticed it.
Post #280361 Tue Nov 16 2010 8:44am
DSL
Mind you these are Land Rovers, once the get to a certain age you spend the whole drive using The Force to feel for the next thing going wrong. If this is all I've got to worry about (which it isn't) then I'm getting off lightly!! Rolling Eyes Rolling Eyes Whistle
Post #280365 Tue Nov 16 2010 9:06am
