Home > Technical > Different Ride Heights?
kismet110
Apologies, I don't have the handbook close to me but last night whilst I was parked up waiting I flicked the rocker switch to the left of the rotary dial near the cubby box to the rear position and the cars height dropped. I stepped outside and the gap between wheel and arch was much smaller than usual. However, when I started driving after a few seconds I got a warning along the lines of "Slow down or car will reduce height"?
I stopped again and pressed the rocker switch back to the front position; it didn't feel like anything happened but the message dissapeared and when I parked up next I noticed the gap between the wheels and arches was pretty huge again.
Is the option I picked a normal driving one or "access" mode"? And if so should I switch it to access mode whenever I park up?
Post #280309 Mon Nov 15 2010 4:07pm
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
just let it do is thing on it's own....
If you lower the car when you stop, as soon as you hit 30 mph, it will automaticly go back to standard heigh Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #280316 Mon Nov 15 2010 4:54pm
