![]() | Home > Australia & New Zealand > Technical |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Assuming they are not empty |
.... but thinking about it now IIRC it is the headlamp jets that share the cigar lighter fuse...
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 ![]() ![]() ![]() |
I believe the pollen filter is inside the car behind the glove box. If you check in Bobby's |
Garrie2283 Member Since: 01 Jul 2009 Location: coal point New South Wales Posts: 14 ![]() ![]() ![]() |
Thanks Guys I will check out both resposes and let you know the results. My headlight washers seem to still work correctly
The headlight washers are serviced by a separate pump.
Hi all, Many thanks for all the help to resolve my queries, the Pollen filter is now fitted and the washer failure seems to be the pump as the fuse is ok and the rear wash is also out. I will pull the pump out for testing as soon as time permits.
