![]() | Home > Technical > Restricted Performance - red triangle warning light |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Approx 8 mile trip steady speed |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
Ah, mine has been happening after about 1 hour at constant speeds so potentially a different problem. Dealer having car for 2 weeks under the guidance of LR since they've been unable to correctly diagnose the problem. Air flow & CSOV sensors already replaced to no avail |
seankenyon Member Since: 21 Jul 2014 Location: Warrington, Cheshire Posts: 35 ![]() ![]() ![]() |
I had this problem today, turns out it was the MAF Sensor, fault only reset but only with ignition either off or on (forgot) but worth noting if it doesn't clear |
EP1 Member Since: 26 Mar 2016 Location: Dorset Posts: 1 ![]() ![]() |
Apologies in advance completely new this forum so not sure if there is a trail I cant fine, my range rover sport had a gear box fault light a couple of weeks ago, took it to the dealership and it was a faulty fuel sensor which they replaced. this morning it has 'gear box fault restricted transmission' anybody had the same problem? |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
Driving on a trip to my country property today in my 2010 TDV8 (about a 35km trip) cruising along at 80km/h up a slight incline and a warning message "Reduced Preformance" with the red triangle came up - whoa what is this, immediately the car felt sluggish with minimal power and the exhaust note changed to a more deeper note. Stopped about 5 minutes later when I got to my destination, lifted the bonnet, had a look, no abnormal heat or smell - no issues there. Returned home about 15 minutes later - no issues. There was no issues before the warning came up - the car drove normally. Gave it a bit of right foot on the way home - performed as normal.
Jimbob36 Member Since: 13 May 2016 Location: Melton mowbray Posts: 74 ![]() ![]() ![]() |
Our 2010 sport is back at the supplying garage for repeatedly doing this! Had it 9 weeks and they have had it back for 2 of those! They are now sending the primary turbo for a check? Codes relate to map and maf. I feel it is not turbo as fault occurs 35 miles into a journey when cruising at 70. This is the last chance as if it faults again I'm rejecting it. Got a letter and presentation ready for it! Shame as the car is lovelly, just been unreliable. We've done 1200 miles in! Not good for a 20 of thousand pound car! |
luckske Member Since: 30 May 2016 Location: Limburg Posts: 33 ![]() ![]() ![]() |
Excuse me if I say something that doesn't make sense, I don't know much technical of a car. But I had similar issues with my TDV6. My parents had my sport before me and they mainly drove very short trips and whenever I took the Sport and drove on the highway, accelerating, the car would say reduced performance and I would have to park the car to the side, wait for 5 minutes and it would then drive like nothing ever happend. This would only happen when the engine was cold. After a (yearly) service at our LR dealer I've never had that problem anymore - so perhaps it's nothing more than a filter of some sorts (air or diesel filter) they replace during a routine service? |
Sounds like a similar fault to ours. It had stood on the forecourt from October to May. I suspect a sticky linkage but faults are air flow value related. |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 ![]() ![]() |
Just happened to me on the way home, the red triangle of doom and uncertainty! |
That's exactly the symptoms which mine had. Over a period of 6 months the dealer changed various sensors under instruction from LR. In the end LR agreed what everyone else knew, primary turbo fault. Finally changed under warranty and not a hiccup over 7000miles since. There is another thread on the issue somewhere However, there are apparently a multitude of things which can cause restricted performance and many just throw up the same codes. In my case LRs approach in trying to save money on warranty repairs must have cost them dearly. Still, despite the inconvenience caused over the period, at least mine has a few new parts fitted, albeit unnecessary ![]() BTW, if they are sending the turbo for a check over then they have already done or will do 90% of the work involved in changing it since to remove & refit the turbo is normally a body off job |
Well garage replaced primary turbo and guess what? It faulted on them! I'm glad it's done it to them as they now can't hide from it! The garage have been ace but I don't know where they go from here. They are now changing the turbo shutoff valve. I believe it's maf related but I'm leaving it entirely to them now. |
So they have now replaced the shutoff valve and map sensor. Can't make it fault but you couldn't before. Getting it back tomorrow but I'm still not convinced, and more to the point neither are they. Feel really sorry for them as they have tried, but if it faults again it gone. |
Drives far better since they have had alignment and balancing done again, properly! Engine is nice and responsive so time will tell. Fingers crossed as it really is a lovelly car. |
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 ![]() ![]() ![]() |
This happened to my 2010 TDV6 this morning. Exited my drive and as soon as I was on my side of the road ‘Restricted Performance’ flashed up. The car would not accelerate above wimpy. Look in my mirror and a 40 toner now bearing down on me. 400m later the engine splutter a few times and normal power resumed, but still displaying the red triangle.
