Home > Technical > HEADLIGHTS
tomdigym
Scotland 2007 Range Rover Sport TDV6 HSE Stornoway Grey
HEADLIGHTS
Hi new to the forum and got a question already,can anyone tell me if you
can change the headlight glass or is it a complete unit.My car is a 07 HSE.
Cheers Tommy
Post #274188 Wed Aug 18 2010 9:07pm
As far as I know it's a complete unit. 2005 Zambezi TDV6 - Gone but not forgotten
Post #274217 Thu Aug 19 2010 12:20pm
AG09
United Kingdom 2009 Range Rover Sport TDV6 SE Zermatt Silver
Technically yes you can do. The lens is held on with some spring clips and some rubber adhesive. Remove the spring clips and heat the edge surround with a heat gun and pry the glass front off. Reverse the process to refit. Google for fitting LED running lights etc. it's the same process.
The problem is you cant just buy the clear perspex front on its own. As VA says, it's a complete, and very expensive, unit.
Post #274234 Thu Aug 19 2010 6:30pm
