Home > Technical > Left rear door will not unlock
RRSTDV8DK
Denmark 2007 Range Rover Sport TDV8 HSE Stornoway Grey
When I unlock the car, the left rear door will not unlock. When I try to open the door from the inside it will not open, and I can not unlock it from the inside.
Anybody tried this and what was the solution? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #270029 Wed Jun 30 2010 7:28pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
Did you have the child lock on? Cause thats why it would not open from inside. Can you hear the motor working on the door or not?
Post #270032 Wed Jun 30 2010 7:42pm
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi. Sit in the car and try and operate the door latch as you normally would. Once you have pulled the door latch outwards try pressing the unlock button on your key fob. This happened on mine with the same door and it would only open this way by me assisting the latch. It appeared to lack the power to operate on its own, ie without help. I suspected possibly a weak solenoid but they just replaced the complete latch under warrenty. Try and see if this opens your door for starters. Hope this helps.
Post #270033 Wed Jun 30 2010 7:45pm
NickM
I have same issue on rear drivers door but can never find the child lock. Point me in the right direction pleaser...thanks
Post #270034 Wed Jun 30 2010 7:46pm
JC1
Rear drivers door Shocked ................................ I hate back seat drivers Thumbs Up Thumbs Up MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far.
Post #270041 Wed Jun 30 2010 9:03pm
RRSTDV8DK
Hi sweetafton - Child lock off, actually it has never been on. It sounds like it unlocks, but no.
Hi Accyis - thanks, will try. I had the same issue with the drivers door two years ago and they changed it under warranty, but now there is no more warranty ... ran out in march RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #270044 Wed Jun 30 2010 10:05pm
RRSTDV8DK
it does not sound like the motor is working. When inside the car and opening via the door latch and then the key fob it works. But still no remote lock. Is the only solution to change the whole lock? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #270067 Thu Jul 01 2010 8:57am
accyis
Thats what they changed on ours under warranty. They probably throw parts at it.
Post #270069 Thu Jul 01 2010 9:21am
RRSTDV8DK
Ok - anybody got a manual on how to change the lock and which part numbers you need? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #270100 Thu Jul 01 2010 4:07pm
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Had the same problem Luckily opened from inside, not had problem since.
Supporting the London Air Ambulance with my Brothers
Post #270106 Thu Jul 01 2010 5:03pm
RRSTDV8DK
It's a miracle. I had no time to sort the problem before the summer and now it works all fine again.
My Range Rover Sport is self healing Bow down RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #273622 Wed Aug 11 2010 12:01pm
