Home > Technical > Extra security needed....
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
I need some help / advice on immobilising my RRS.
I am driving through Europe starting next week and just know that with all the best will in the world I will be forced to leave my RRS in some very dodgy places.
I wondered if anyone knows of a good / quick way to immobilise a TDV6?
Is there a fuel pump fuse or other fuse I can remove without throwing any fault codes when replaced?
I know that anyone determined enough will see straight through this, but hopefully the regular scum will get put off before finding another fuse or bridge wire.
Any thoughts?
Post #268815 Thu Jun 17 2010 2:04pm
MAW
Take a shotgun and sleep in it Whistle
Insure it and don't worry - pulling a fuse means that they'll have smashed there way in before finding it wont go - do you want to wake up to see it in bits or on fire or to find and empty space (obv neither ideally) but i'd rather see it go than in bits....
Make sure you leave nothing of value in it and nothing personal, leave you glove boxes empty and open if that bad an area... same with the tonnet cover - a pain but better than loss of personal stuff
...... where you heading Question
Post #268818 Thu Jun 17 2010 2:20pm
Lawrence22
2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Something very visable like a steering lock can help. Thieves will usually head for the next vehicle if they see something that is going to delay them. Said RRS is now on order.
Post #268822 Thu Jun 17 2010 2:36pm
airwolf222helicopters
Give jason a call at Jasons autosecurity on
07973143501
he will give u some the correct advice
dave
Post #268875 Fri Jun 18 2010 6:53am
07973143501
he will give u the correct advice
dave
Post #268876 Fri Jun 18 2010 6:55am
Rupert
Ireland
Can an RRS actually be driven away without the keys ?
I thought that was the reason the thieving scum have turned to breaking into houses to take the keys, as there is no way of “hotwiring” modern motors anymore !
Post #268902 Fri Jun 18 2010 1:49pm
Small time crack heads it makes it very hard as there brain dead looking for next fix
But if the pro's want it nothing stops them ! All u have to do is make it harder for them so they decide to nick the next car that don't have added security ..
The factory alarms are ok but there are better than can be fitted
Dave
Post #268906 Fri Jun 18 2010 2:08pm
