Home > General > TDV8 Problems
rasspe
United Kingdom 2007 Range Rover Sport TDV8 HSE Rimini Red
TDV8 Problems
HI Guys
As some of you may have seen, I have a post about the exhaust gasket leaking, this was repaired after 3 weeks and then 2 weeks latter the brake switch went causing the electics to shut down, then now a week latter the whistling restarted took to dealers to be told the bolts to the turbo were it joins the manifold.
Can anyone help with rejecting this vehicle as the dealer has come back with a what I consider a poor discount on a new Discovery.
This car has been a dog ever since ownership.
It has had repairs to the transfer box,
Lower ball joints both sides
Had the EGR Coolers replaced
Front PDC Loom had to be replaced due the chaffing
Tailgate Stuts
Heated rear window terminals failed due to water ingress
Brake Booster and Pump replaced
Power steering fluid replaced
Replacement of Front ARB Bushes
Any help would be gratefull
Richard
Post #268718 Wed Jun 16 2010 2:14pm
