Home > Technical > Dead battery...how to put the vehicle in neutral???? HELP |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
foot on brake, key turned in ignition should do it.......but Im not sure as Ive never had a dead battery... |
Wed May 26 2010 3:26pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
That shouldn't work if battery completely dead as the solenoid on the brake pedal will need power to unlock the gear selector |
Wed May 26 2010 3:32pm |
Frosty_Power Member Since: 02 Oct 2008 Location: Calgary Posts: 93 |
Nope, doesn't work. Tried several times. |
Wed May 26 2010 4:39pm |
If this is the case, I imagine I'm screwed and have to purchase a battery charger . I don't understand why this would not be possible since whenever I usually need a boost the vehicle is always parked in the worst spots to try and get a boost from another vehicle . Is it just the RRS with this design or are other sport utility vehicles like this? |
Wed May 26 2010 4:53pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
mine goes flat after a short time too, had too many flat battries in the 2.5 years of ownership
Wed May 26 2010 5:31pm |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 |
There is an emergency release procedure. I know how it's done in a D3, but for the RRS, if it's not outlined in the manual, try the GTR online.
Thu May 27 2010 12:11am |
I thought about an emergency release - there is for the EPB but i cannot recall hearing of one for gear select.....
Thu May 27 2010 5:45am |
Alex Member Since: 06 Mar 2008 Location: Luxembourg Posts: 3 |
Hi,
Thu May 27 2010 7:25am |
As MAW said, EPB emergency there is but I too have not heard of emergency gear select release! Interesting.
Thu May 27 2010 10:05am |
Good advice. Or you could just carry the jump battery to the car and jump start with it. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thu May 27 2010 10:13am |
In the D3, you remove the trim panel behind the EPB switch. The 'interlock' override switch is a small white tab that you can lift up and then move the gear lever out of park. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Fri May 28 2010 12:03am |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
First make sure the car cannot move if the gear lever is taken out of Park or the EPB accidently released (by chocking the wheels if necessary).
Sat May 29 2010 2:40pm |
Nice one new one to me |
Sat May 29 2010 4:07pm |
Malaysia Boleh!
Sun May 30 2010 10:16pm |
