Home > Maintenance & Modifications > help fitting resistors to 2010 rear lights
td6006
2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi has anyone fitted ballast resistors to the 2010 rear led lights to stop fast indicator flash on dash when fitting lights to to earlier models.I know I need 50w 6ohms resistors but how do I wire them in ? Question
Post #263520 Mon Apr 19 2010 8:49pm
NightFox
Not an answer, but does this help?
http://www.rrsport.co.uk/forum/topic17810.html Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #263523 Mon Apr 19 2010 9:20pm
sbkim
2008 Range Rover Sport Supercharged Java Black
Bump - any update on adding the resistors? Thanks!
Post #265889 Wed May 12 2010 5:07pm
RRS PIMP
N/S - connect one end of the resistor to the green/red wire and the other end to an earth wire.
O/S - connect one end of the resistor to the green/white wire and the other end to an earth wire.
I don't advise fitting the resistors to the back of the light units, much safer to fit them inside the vehicle, to avoid any contact with water.
I'll try and uploads some pics for you.
Check my gallery for pics.
Post #265931 Wed May 12 2010 10:46pm
Incartv
United Kingdom 2007 Range Rover Sport TDV6 HSE Alaska White
Cheers guys just used resistor info
Working fine Smile
Post #295579 Sun Apr 10 2011 8:27pm
