![]() | Home > Technical > Cradle phone connection |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
"Approved" phone list has cradle compatibility (same for all LR vehicles):
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
HansNL,
Toodeep Member Since: 09 Jul 2005 Posts: 42 ![]() ![]() |
And, HansNL, don't be tempted to get the improved Nokia 6230i as other owners have found only the plain 6230 works. I can't speak for any other phones that might be on the compatability list. Range Rover Sport TdV6HSE in Bonatti Grey + 20" Stormer wheels (ex X5 and ML driver) |
The 6230i is not on the list. |
True, but a few people have been sold them presumably having been told by some white-shirted, hair-gelled phone sales assistant that "You don't wanna buy that, you wanna buy this." I freely admit that I would have bought a 6230i had I not had the benefit of others' experience believing the only difference to be a better camera, improved memory and a silver finish. The handbook probably pre-dates the phone and anyway.....what could possibly go wrong?? Range Rover Sport TdV6HSE in Bonatti Grey + 20" Stormer wheels (ex X5 and ML driver) |
HansNL Member Since: 28 May 2005 Location: Lelystad Posts: 19 ![]() ![]() |
OK, everything solved. I bought an older Nokia 6100 + cradle CR-3 and copied the whole phonebook on the duplo SIM-card, so this phone will stay in the cradle for ever. Now I can select to use the Nokia 6100 in the cradle or my Nokia 9300 with bluetooth |
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 ![]() ![]() ![]() |
Hi
Cradle 3 (Part No. XVE 50020) is for the Land Rover factory system. (Read the PDF, and you'll see the "approved" phones for it.) |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Question:
nickp Member Since: 27 May 2005 Location: Leicestershire Posts: 111 ![]() ![]() ![]() |
RRUK
Correct. You are expecting far too much if you want parallel phone support. |
willem54 Member Since: 29 May 2005 Posts: 12 ![]() ![]() |
Nokia 6230 is oke |
623O Works ok for me too. Its out there somewhere. Second V10 Treg on the drive at the moment. |
I would hope... the 6230 is on the list! |
