![]() | Home > Tips & Tricks > Tricks to correct uneven wear Contis? |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Because is a pain to explain to the cops that is feature of the RRS/Conti combo and they might not listen |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
what is the law on tread depth across the % of a tyre width 2014 5.0SC AB
I do not know the law in UK, do not drive there, I know they will give me hard time here, and even if I was ok I'd still have to waste time discussing the issue with them. Knowing as some of them work they then might start looking for other problem just to "win" |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 ![]() ![]() |
what tyre pressure is everyone using in the conti's,on the drivers door i think it says 42 rear and 36 front this is with 4 passengers and luggage.i very rarely have 4 passengers + luggage.and what pressures do i use when towing a caravan.any advice please.sorry for hijacking the thread |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
A minimum of 1.6mm in a continuous band throughout the central three-quarters of the tread width, throughout the whole of the circumference (see illustration below). ![]()
I tow a caravan and inflate for 4 passengers and luggage when towing then decrease to lower pressure on door when I unhitch after tyres cool down - min 3 hours. I keep a small compressor in boot with a tyre gauge ![]() Still hoping for a S2 one day! |
Kato RRS Member Since: 31 Oct 2012 Location: West lothian Posts: 9 ![]() ![]() ![]() |
Unless this part of the tyre is designed to wear quicker than the rest then the tyre is illegal when the base of the groove of any of the original tread pattern is not clearly visible. Reg 27 construction and use regs. Unless this has hanged of course. RRS for on road 1985 LR 90 for off road Dolomite Sprint for fun |
