Home > General > Exhaust question
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Exhaust question
Hi. I've recently purchased my first rrsport and have a question with regards to the exhaust sytem. As well as the obvious twin tail pipes at the rear of the vehicle is there a exhaust outlet at the front of the vehicle. I've noticed the exhaust gases (visual and smell) when starting up the engine in cold weather. Don't want to sound like a novice but all info is welcome at the moment whilst I get to grips with the beast. Thank you.[/u]
Post #254424 Mon Feb 08 2010 7:46pm
It's the fuel burning heater (or alternatively, your car is about to explode... run, RUN!!!) Whistle
Post #254437 Mon Feb 08 2010 8:04pm
White Rabbit
Ireland 2007 Range Rover Sport TDV6 HSE Rimini Red
Greetings,
The front smoke is perfectly normal, clicks into working when the engine/weather is very cold, assists in engine warm up and heater, switches off in a short time. Good luck with the RRS fine vehicle, :) :)
Post #254449 Mon Feb 08 2010 8:36pm
accyis
Thank you for your replies. I had identified a small bore pipe towards the front near side and assumed it was happening for a reason. Quite rightly it only appears to happen for a short while on start up. Thanks again, I've plenty more questions to follow and I look forward to receiving your help.
Post #254452 Mon Feb 08 2010 9:03pm
