Home > Technical > Full size spare ?
buster11
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Full size spare ?
I am running on 20's at the moment, and on inspected the spare wheel noticed that is a 275/50/19.
If I buy a matching 20" wheel - will it fit in the spare wheel housing ? I could of course take the wheel off and try it - but I imagine someone else will probably already know the answer !
Post #252452 Thu Jan 28 2010 10:26pm
Tim in Scotland
Was asked on Monday in the General section......................... http://www.rrsport.co.uk/forum/topic16676.html 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #252453 Thu Jan 28 2010 10:31pm
buster11
Thanks Tim ! once again Thumbs Up
Post #252455 Thu Jan 28 2010 10:35pm
Bob.
A 10 spoke 20" wheel with a standard 275/40R20 tyre will stow underneath in place of the 255/50R19 on the black alloy (the 20" is in fact 11mm smaller in diameter than the 19") but due to being wider it will hang 20mm lower, reducing departure angle. Also the flat rim face of the alloy where it is pulled up against the rubber pads under the car may get scuffed. If you are not worried about departure angle and have a spare you don't mind not looking perfect it solves the problem of a 50mph limit if you have to use it.
255/50R19 tyre on standard 19x8" black spare wheel
275/40R20 tyre on standard 10 spoke 20x9.5" alloy
Post #252586 Fri Jan 29 2010 7:23pm
