Home > Technical > HELP!!
D Hall
HELP!!
Hi,
I have a Range Rover Sport V6 Auto 2006. It starts fine, but when setting of from a stand still it labours realy badly until the turbo comes in! Also if you try to accelerate in a higher gear after reducing speed it labours again until the turbo comes in again. can anyone help diagnose problem? Warranty recently expired, typical!!
Thanks
Post #252276 Wed Jan 27 2010 11:27pm
Tim in Scotland
Sounds like an EGR valve is sticking or turbo has a problem - if you do a search you will find more info about it. It is a common problem with TDV6. Another problem with similar results is a small hole in one of the flexible pipes to the turbo. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #252278 Wed Jan 27 2010 11:31pm
