![]() | Home > General > Vehicle trackers and a few other Qs |
Shao_Khan Member Since: 22 Aug 2008 Location: Concrete Cow Central Posts: 105 ![]() ![]() ![]() |
I always think a tracker is a bit personnal. I had on on our RRS because it made quite a differenc eon our insurance quotes, but in our new post code it makes F all difference, so a bit pointless. If it gets nicked, i'd rather it dissapeared and the insurance gave me a new one, I don't want it if some scrote has been riding in it. |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Hi Dave,
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Does it? Not that I've properly tried it but didn't think it did and I have the same issue of shutting it and it not shutting properly so reopening and having to slam it shut. |
Dave1888 Member Since: 09 Jan 2010 Location: Livi Posts: 14 ![]() ![]() ![]() |
Thanks for the answers guys, i think i might give the tracker a miss as like Shao says i dont think i would want it back. 2007 RRS V6 2.7 SE
caperbility Member Since: 14 Jan 2010 Location: landscaping the world Posts: 221 ![]() ![]() ![]() |
Mines the same mate hardly ever shuts first time so have to give it a slam also. |
Well, My 2007 definately had it and I never had a problem with it. My new 2010 also has it. I'm not sure if it has always been on the cars though, maybe earlier years didn't get it. Have a look in your user manual, it should tell you if your car has it or not. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Been out to the car to check and it does, I closed then within a few seconds it lock proper. 2007 RRS V6 2.7 SE
Just been to the shop and no it doesnt work on mine. |
DJ your car might be pre-soft close I think it only came into the spec sheet in 2007! To see if you have it pull the rear hatch down gently until about an inch from closed and then let it fall without you pushing. The hatch will pull itself closed the last inch and lock itself. There is a video somewhere in the forum if you use the search with soft+close+boot as the search title 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
XUJG Member Since: 03 Aug 2006 Location: Left Posts: 437 ![]() |
If the car was fully covered for a full replacement then I agree but insurance companies will try everything possible to minimise their cost. |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
On the tracker subject the following makes interetsing reading, need to check with my supplier if i am at risk |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
From one of your previous lines of work you should remember PAKNET, Tracker was built on top of the Paknet system and I installed the first mobile Paknet system in Scotland, used it for sending data and positioning information from the first CCTV Incident Command Vehicle we built back to a central station. Sons of dogs come hither and get flesh Clan Cameron |
Alicatt, hope you are well. My concern is that my supplier is using a GSM / GPS based product which can be blocked by the use of this type of unit http://www.navigadget.com/index.php/2007/01/29/gps-and-gsm-jammer and once the car is in a container the jammer is switched off therefore making it invisible to detection from initial theft. I am going to ask my supplier if they have any technology built in to safe gauard against this method of jamming. |
