![]() | Home > General > Mileage correction? can you tell |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
not sure about the answer Steve, however out of interest when would clocking a car not be just for gain? |
steve2026 Member Since: 30 Dec 2009 Location: Glos UK Posts: 122 ![]() ![]() |
If for some reason you changed the clocks or binnacle you might want the mileage reset to original. |
ok - gotcha - makes sense |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
in a old car I had (Kia Sportage |
I suppose 2k is neither here nor there, but 20k starts to misrepresent the age/use of the car. I don't suppose the insurance company would have dismissed it so quickly then |
There must be some form of memory otherwise everytime you get a flat battery, or disconnected it, you would loose your odo-reading 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
i agree that there is a memory, but when people do correct the mileage do they also wipe the memory, or , like your computer, you may think you've wiped everything off, but it's still there somewhere, just needs someone with the right knowledge and software to find it.
NasMan Member Since: 06 Jan 2010 Location: West London Posts: 102 ![]() ![]() ![]() |
Of course it could just be correct |
SachaR Member Since: 13 Nov 2007 Location: Udine Posts: 508 ![]() ![]() ![]() |
A good dealer should be able to check the mileage as I believe the ecu of abs and other safety devices store the mileage of the car ( its what my friend at the local dealer informed me of). RRS TDV8 HSE 2007- JAVA Black/Black interior,
Ok, Guess I'm being a bit vague, as posted on here I'm very close to owning a rrs, just having a service before I pick it up, it's a private sale.
Doesn't look like you've got much to worry about - given the discrepancy has been explained by two sources? |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
they answer is yes it can be done, the vehicle does store it in multiple places 99% of the time its 3 separate locations
Believe me I've got that many hats on I can't get through the door, as said, this was picked up by doing a dealer check, the car is in perfect condition, ( as you would expect from a car with 25K on the clock ), the mot check was fine.
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
1. user on here Bobby will tell you if there is any way to know (he is our LR inside man, as well as others)
