Home > Off Roading & Green Laning > Shackles...
C10KO
Shackles...
Can anyone tell me what is the right size shackle for RRS?
I have been looking at the famous four site and they offer a 19mm and 22mm option. Which one shall I go for?
Cheers Thumbs Up
Post #246944 Mon Dec 28 2009 6:10pm
What weight capacity do they have? Forget the size look for the load rating. 4 Ton + should be enough. 2005 Zambezi TDV6 - Gone but not forgotten
Post #246945 Mon Dec 28 2009 6:15pm
C10KO
VA, the smaller one has 9.75 tons and the larger one 14.25 tons Shocked
Post #246946 Mon Dec 28 2009 6:17pm
Then either will be suitable. 2005 Zambezi TDV6 - Gone but not forgotten
Post #246947 Mon Dec 28 2009 6:20pm
C10KO
Thanks mate Thumbs Up
Post #246949 Mon Dec 28 2009 6:30pm
Tim in Scotland
Actually the really important things are the gap across the jaws and the diameter of the pin! If the jaw isn't wide enough then the shackle will not fit over the recovery eye and if the diameter of the pin is bigger than the hole in the recovery eye...... well I thin k you will get the idea! Coko get your tape measure out before buying them. BTW I noticed in Halfords today that they are now selling a red elasticated recovery strop with a closed hook on one end and rated at 4 tonnes which should also be strong enough for most work that owners here will require. You will find it here on their website http://www.halfords.com/webapp/wcs/stores/...yId_165551 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #246953 Mon Dec 28 2009 7:19pm
C10KO
Thanks Tim Thumbs Up
What I am after is only a shackle, to make life easier in case I get stuck Rolling Eyes if that makes sense Laughing
Post #246956 Mon Dec 28 2009 7:36pm
Tim in Scotland
Thumbs Up 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #246966 Mon Dec 28 2009 9:53pm
Leo
Kenya
Tim in Scotland wrote:
they are now selling a red elasticated recovery strop with a closed hook on one end and rated at 4 tonnes ...
If a 'snatch' strap, then a 4T rating is not enough. For snatch straps, the minimum breaking strength should be between 2 to 3 times the car's weight (GVM). Some good info here: http://www.arb.com.au/getting-started/reco...ipment.php
Post #246968 Mon Dec 28 2009 9:55pm
Tim in Scotland
I wouldn't recommend a snatch rope to anybody, they are lethal in inexperienced hands and pretty dangerous when folks who think they know how to use them try to. I've seen too many bits of tow bar and even rearcross members from Defenders come off with sntach/kinetic ropes to even have one in my kit box of recovery gear. Halfords state it is an elastic towrope to keep the slack part from rubbing and fraying on the road when towing. Sorry maybe I gave the wrong impression calling it a recovery rope, it is a tow rope 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #246970 Mon Dec 28 2009 10:04pm
I think they sell 'Snatch straps' on www.annsummers.co.uk
Whistle Runner up - 2009 Best Avatar Award Sad
Post #246982 Tue Dec 29 2009 6:06am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
They are quite commonly used in Australia Tim, in particular where Sand based driving is concerned. As you say if not set up properly or in the hands of the inexperienced they can be lethal.. or at the very least cause severe damage to either vehicle that is doing the snatching through either a poor set up, using D shackles to join them etc.
That said many of the off road courses teach you how to and when to use the snatch verses rope etc.. how to set them up.. and the Range Rover club actually get their members on the Sand training courses to actually go through a recovery to show the best and most efficient approach. It usually comes down to common sense and applying the grey cells.. Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #246983 Tue Dec 29 2009 7:42am
Tim in Scotland
They are very commonly used up here in mud Zilch, but a lot of people do not appreciate the amount of energy these things can absorb - they are very useful when used properly and in the right hands and I have been recovered on several occasions by their use but I prefer to use a winchrope and winch and do the job slowly. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #246991 Tue Dec 29 2009 9:48am
MAW
Re: Shackles...
Cheers Thumbs Up
Handystraps on fleabay also do a good range - i ve just bought a recovery strap from them Thumbs Up
Post #246992 Tue Dec 29 2009 9:56am
Zilch
agree Tim, you should use the best tools for the situation... our local environment calls for both types of recovery, however with ample opportunities for Sand/Dune based driving.. Snatch is usually the only effective method as there is nothing to anchor on, kinetic energy is normally required to prevent the recovering vehicle bogging down as well .. which i have seen with mine and a D3 Laughing
wait for the forum to pick up on the snatch comment Whistle
Guid Hogmanay Tim.. Thumbs Up Another Pommie Bar Steward down under
Post #246997 Tue Dec 29 2009 10:01am
