Home > Technical > HDC Fault.
Aidan
Ireland 2006 Range Rover Sport TDV6 HSE Buckingham Blue
HDC Fault.
My motor has developed a nasty habit of throwing up this message when I turn the ignition on "HDC Fault, Special applications not available" now to coincide with this new "feature" it has run its battery flat for no apparent reason in the past 2 weeks. Anyone got any ideas ?
I thinks its gots sumfing to do with the handbrake!!!! It can't be that hard on diesel???
'06 TDV6 Buck Blue. 22s.
Post #244761 Mon Dec 07 2009 4:41pm
Tim in Scotland
The HDC fault light is a sign of a failing battery! You need a need a new battery mate 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #244762 Mon Dec 07 2009 4:44pm
949BFN
South Africa 2007 Range Rover Sport Supercharged Chawton White
Second that. Had the same issue. New battery solved it. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C)
Post #244768 Mon Dec 07 2009 6:05pm
NeilN
South Africa 2008 Range Rover Sport TDV8 HSE Atacama Sand
Hi Aidan
If you have a tracker system fitted it may need a new battery. When the tracker battery gives up it starts draining the car batrtery - and it can drain quite quickly.
Good luck
Neil
Post #244769 Mon Dec 07 2009 6:08pm
shuzzy
I have just recently started getting the HDC fault for a second after starting for the first time. However have had a new battery couple of months ago, so cant be that.......
Post #245246 Sun Dec 13 2009 4:28am
highfellzippy
DEALER TOLD ME ITS AN INDICATION THAT UPON STARTING THE BATTERY VOLTAGE IS SLIGHTLY LOW
Post #251509 Sun Jan 24 2010 10:26am
