Home > Australia & New Zealand > Winch fitting availability in Australia?
Govette
Australia 2007 Range Rover Sport TDV8 S Bonatti Grey
Hey guys,
Hopefully without asking you to repeat ground you've already covered, has anyone found a dealer that can get hold of the winch cradle (preferably without winch), or at least understand that someone might need one?
Cheers 4wding only starts when you have to get out the cab. Everything before that is just driving on crap roads!
Post #244180 Wed Dec 02 2009 11:26am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I'm not aware of anyone in Aus who has fitted the factory winch plate and/or protector plate..
I would hate to see dealer prices for those if a dealer or Land Rover Australia actually brought them into Australia..
Look through the Australia and NZ forum section you'll see a few discussion about genuine LR off road products, and unfortunately most are met with negative end results due to cost or similar..
Fellow VIC forum member BKHK even had to personally import the LR seat covers because the dealers wouldn't do them!
Post #244183 Wed Dec 02 2009 11:36am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
The sump plate is a G4 accessory as is the winch.
however pretty certain the winch mounting is the same for Disco 3 as RRS so might give you more scope. If you can get one secondhand then you could fit your own winch which would be a lot cheaper than the LR factory fit option.
The sump guard is totally different though.
If not available from your dealers then try contacting UK dealer as some will export.
Forum sponsrs duckworths and Yeovil Landrovers on disco 3 do export as far as i know
The winch kit in UK is around £1800 and sump plate £450 so loads of dosh Exclamation
Post #244195 Wed Dec 02 2009 12:31pm
The winch plate is indeed the same as the D3 but there are a couple of differences with the mounting kit. RLD on our sister site might be able to fabricate the kit if needed. 2005 Zambezi TDV6 - Gone but not forgotten
Post #244197 Wed Dec 02 2009 12:52pm
Govette
Thanks very much for the help guys. Yep, the LR dealer in Townsville was able to find the winch kit on the computer, (only after I supplied him with the part number??!!). Can back at a little under $5000 not including fitting. Errr, Censored that!! To be honest, I think I'm at the stage of just building my own, and try not to interfer too much with the crush pulse dynamics. Shame Rovertym and Safarigard aren't making any, what with the exchange rate being so good and all. 4wding only starts when you have to get out the cab. Everything before that is just driving on crap roads!
Post #244497 Sat Dec 05 2009 12:04am
Leo
Kenya
Building your own is probably the best option, or check costs of importing from the UK or USA.
Post #244518 Sat Dec 05 2009 11:42am
