Home > Off Topic > Need some IT advice....
Page 1 of 4 1234>
got a 100 mbit connect now Cool
directly connected to my comp it gives full speed ! Cool
but connected through a Router (Netgear) it gives only 33 mbit Big Cry
any advice on a VERY GOOD Router that gives the full bandwidth...... ?
Thanks Smile
Post #237460 Mon Sep 21 2009 9:03am
As yet we don't get 100Mb cable in the UK (although it's coming), so I've not seen one to recommend...
Doesn't your ISP provide one?
Confused
Post #237463 Mon Sep 21 2009 9:15am
Wozz
Assuming your router is not ancient you should definitely be seeing up to 100 Mbits. I had a quick look on my router here (which is a Netgear) and there are no traffic management/throttling options so I should imagine yours is the same). It might be worth a call to Netgear to understand why?
I don't use cable (can't get it out in the sticks here) so not sure what the issue could be. I am not sure buying a new router will solve the problem as its likely something wrong with the setup and not the router. If you are using wireless to subsequently connect to the router then thats where you will see the downturn in the connection speed and 30-54Mbps would be about the right range dependent upone what other "noise" you have in the house such as cordless telephones.
I'd check the setup on the router for traffic management options (if any) and then perhaps contact Netgear and ascertain what is holding back the bandwidth. Routers and switches connected by cable have been operating as 10/100 Mbps since time began so I can't imagine your router won't work at 100 Mbps.
If the problem is with wireless then just upgrade to an 802.11n router which will run in excess of 100 Mbps. you will also need to upgrade your wireless network cards if they do not operate at this protocol also. if you have to uprade I would hold on for the dual band routers which are currently available in the US but not in Europe (last time I checked). THat way if the problem is related to other "noise" in the house then you can switch the operating band to move away from the 2.4 Ghz that most domestic appliances would operate at.
Asides from that I don't know what to suggest but, afaik, a new router won't magically solve the problem. WINNER - 2009 Best Newcomer Award
'09 TDV6 XS Stornaway Grey
'06 BMW 730 D SE (Gone)
'08 A4 TDi SLine Avant (Gone)
Large pack of Flake Cakes (Gone)
6 pack of Guiness (Gone)
Post #237468 Mon Sep 21 2009 9:34am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Mmmm... I'm no expert, but my thinking would be that unless you have a 'wireless n' router and capable similar capable network card you will not get anywhere near 100MBits actual on your wireless.
See here for details:
http://en.wikipedia.org/wiki/IEEE_802.11
Wireless n or 802.11n was draft until only a couple of weeks ago. I have a 'wireless n' router, but need to get the USB dongle as my laptops intenal wireless network card only supports up to g...
As I said no real netowrk expert, so happy to be corrected by more informed types...
Post #237470 Mon Sep 21 2009 10:19am
Angel needs 100Mb on the WAN port, not on the LAN side Wink
Mate, how does your cable provider terminate at your wall socket? Is it a network port? i.e. could you buy a standard ethernet router and use that or does it need to be a cable modem?
Post #237474 Mon Sep 21 2009 10:48am
Wozz
Why would someone want that in their home? Confused
EDIT: Ah sorry I get it now! I wouldn't assume that the problem is on the WAN side simply because it works when directly connected myself but I am guessing you know more than I do about Angels setup WINNER - 2009 Best Newcomer Award
Post #237481 Mon Sep 21 2009 11:05am
ok i clarifies:
Provider *provided* me with a Motorola cable modem ---------------> netgear router (not wireless) - ----------> switch to dispatch all the rooms in the house ------> but only 2 PS3s and my comp connected - SWMBO got her own provider Cool
Post #237483 Mon Sep 21 2009 11:20am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Misery should be along soon, he will know Whistle Whistle
Windows 3.1 anyone? L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #237489 Mon Sep 21 2009 11:45am
Angel is lucky enough to have 100Mb cable service, yet his router only "manages" 33Mb on the WAN side, meaning from his PC to the "internet" he'll only ever get what the router can manage, let alone what he gets on his own network.... what Angel is after is a router that will give him a 100Mb carrier so that the internet at large is his bottleneck, not like 99% of us, the connection into our homes.
Not that I do IT for a living or anything.... Wink
Post #237490 Mon Sep 21 2009 12:00pm
Jonny Fresh
have you tried switching it off and on again? Whistle
Post #237491 Mon Sep 21 2009 12:06pm
haha - well our house is equipped with 2 x Cat 5 cables in every single room (toilets included) with a switch in the cellar to dispatch Wink its cause i don't like Wlan Wink
Post #237492 Mon Sep 21 2009 12:08pm
islider
Angel does your switch support splitting and amplifying?
(Can bandwith be amplified or maintained once split???)
I.e. does it provide switching by only splitting the bandwith per component. As 2 PS3s and 1 computer would equal 100mb /3 equals 33mb at each component.
I could be completely wrong. Confused
As I also have Cat5 cabling to all rooms in the house, except the games room. But never got round to fitting the Cat5 sockets in the rooms or fitting a switcher, the cables are still coiled up in the back boxes. Whistle
Must get round to finishing that. Laughing Laughing
And if I ever do, you can let me know whats the best switcher. Thumbs Up
Post #237496 Mon Sep 21 2009 12:21pm
if its going through the switch then this well may be the problem
Post #237541 Mon Sep 21 2009 6:40pm
mccalia1
When you say connecting directly to the internet, do you mean via a USB modem or something?
If you're connected to your router via a network card, check to see if your network card duplex settings are set to Full. Gone: RRS : HSE : TDv6 : 57 : Java Black : Ebony : 20"
Post #237549 Mon Sep 21 2009 7:06pm
ayates
United States 2007 Range Rover Sport Supercharged Buckingham Blue
for a good 1000Mbps connection using a non wireless router I would recommend something like a DLink DGL4100 but you will also need a 1000Mbps network adaptor in the PC with a card like a Dlink DGE560T if you have a spare PCI slot.... so you may get most of this bandwidth around your network but I doubt once you get past the modem it will continue.... well at least it doesnt here with our cable service.
BTW DLink is imho the best to setup.... non of this netgear nonsense Wink
www.dlink.de
PS a great switch for the home DGS-2205 Thumbs Up Brit across the Pond Wink
07 TATA (LR) RRS SuperVindaloocharged, Buckingham Blue, Stormers, TPMS, Sunroof, Rear Difflock,PDC front & rear, Privacy, Rear twin DVD, premium ice, mudflaps, premium Ivory leather, lined oak, PTI, Sat Radio.
Post #237570 Tue Sep 22 2009 4:46am
Page 1 of 4 1234>
