![]() | Home > Technical > Side mirrors problem |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
What do you mean you can't control them? If they don't move, it's time for service.
djsaad1 Member Since: 10 Aug 2005 Location: Texas Posts: 254 ![]() ![]() ![]() |
if the dipping is on they will move down when its in reverse and then move all the way up when back in drive. But i cant control them manually from the switch. If the dipping is off then they will still just stay in the high position and I still cant move them manually. I guess its time for service anyways. |
DAVIS Member Since: 27 Dec 2005 Location: Genoa, Nevada Posts: 134 ![]() ![]() ![]() |
grommet, you mention in your reply to djsaad 1 "do all 3" It's my understanding that the reverse dipping feature only controls the 2 side view mirrors, am I missing something? |
I'm talking about initially saving all 3 memory settings the same. (The 1/2/3 buttons on the seat.) Just to prevent initial confusion, especially when using the Lazy Entry feature. |
Thanks for the answer... |
