Home > Technical > 17" Wheels on a RRS?
Jeffrey
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
Did any Sports come equipped with 17" wheels, or are there any that will fit, either genuine or aftermarket? '06 RRS Giverny/Alpaca
'97 Discovery
My Rover Site -- My Photo Site
Post #13648 Sat Feb 18 2006 5:33pm
Roland
Switzerland
The Disco 3, sorry you're in the US, the LR3's 17" should fit, but I am pretty sure you will have to get them from Europe.
Roland
Post #13650 Sat Feb 18 2006 5:48pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
The basic S spec RRS comes with 17" alloys, so you should be able to source them via your local LR dealership.
I take it you only want them for offroading because they could never be described as eye catching.
Post #14202 Wed Feb 22 2006 3:29pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Just FYI, 18" wheel/tire packages are often listed on eBay Motors from local (US) suppliers and are usually fairly cheap, such as:
http://cgi.ebay.com/ebaymotors/18-Range-Ro...4489QQrdZ1
Haven't seen too many 17"ers listed though (again, through US sources), and I check eBay quite often...
Post #14208 Wed Feb 22 2006 4:09pm
Jeffrey
Umberto, I already have a set of stock 18's with Wrangler HP's in the garage. Still, not good offroad tire choices for them either, unless you go with the Nitto Terra Grapplers, which only come in a size one inch smaller in diameter that the stock 18" Conti's. Not my desire. I do check ebay all the time, thanks.
Yes, I want to use them off road. 17's have more tire choices available at this time.
EDITED: I originally said I had 17's. I WANT 17's! The post has been corrected. '06 RRS Giverny/Alpaca
'97 Discovery
Post #14209 Wed Feb 22 2006 5:33pm
Rangie
Australia
I have 17" aftermarket wheels and tyres...
38mm Offset with a 5x120 PCD, the Bore is 73mm
 Ben
Post #22072 Sun Apr 02 2006 10:16am
