Home > Maintenance & Modifications > Oil advice for modifiers
oilman
Site Supporter
If you are modding your car and adding BHP or using it off road then consider your oil choice carefully as the stock manufacturers recommended oil will not give you the protection that your engine requires.
A standard oil will not be thermally stable enough to cope with higher temperatures without "shearing" meaning that the oil will not give the same protection after a couple of thousand miles as it it when it was new.
Let’s start with the fundamentals. An engine is a device for converting fuel into motive power. Car enthusiasts get so deep into the details they lose sight of this!
To get more power, an engine must be modified such that it converts more fuel per minute into power than it did in standard form. To produce 6.6 million foot-pounds per minute of power (ie 200 BHP) a modern engine will burn about 0.5 litres of fuel per minute.(Equivalent to 18mpg at 120mph). So, to increase this output to 300BHP or 9.9 million foot-pounds per minute it must be modified to burn (in theory) 0.75 litres.
However, fuel efficiency often goes out of the window when power is the only consideration, so the true fuel burn will be rather more than 0.75 litres/min.
That’s the fundamental point, here’s the fundamental problem:
Less than 30% of the fuel (assuming it’s petrol) is converted to all those foot-pounds. The rest is thrown away as waste heat. True, most of it goes down the exhaust, but over 10% has to be eliminated from the engine internals, and the first line of defence is the oil.
More power means a bigger heat elimination problem. Every component runs hotter; For instance, piston crowns and rings will be running at 280-300C instead of a more normal 240-260C, so it is essential that the oil films on cylinder walls provide an efficient heat path to the block casting, and finally to the coolant.
Any breakdown or carbonisation of the oil will restrict the heat transfer area, leading to serious overheating.
A modern synthetic lubricant based on true temperature-resistant synthetics is essential for long-term reliability. At 250C+, a mineral or hydrocracked mineral oil, particularly a 5W/X or 10W/X grade, is surprisingly volatile, and an oil film around this temperature will be severely depleted by evaporation loss.
Back in the 1970s the solution was to use a thick oil, typically 20W/50; in the late 1980s even 10W/60 grades were used. But in modern very high RPM engines with efficient high-delivery oil pumps thick oils waste power, and impede heat transfer in some situations.
A light viscosity good synthetic formulated for severe competition use is the logical and intelligent choice for the 21st century.
You must seriously consider a "true" synthetic for "shear stability" and the right level of protection.
Petroleum oils tend to have low resistance to “shearing” because petroleum oils are made with light weight basestocks to begin with, they tend to burn off easily in high temperature conditions which causes deposit formation and oil consumption.
As a result of excessive oil burning and susceptibility to shearing (as well as other factors) petroleum oils must be changed more frequently than synthetics.
True synthetic oils (PAO’s and Esters) contain basically no waxy contamination to cause crystallization and oil thickening at cold temperatures. In addition, synthetic basestocks do not thin out very much as temperatures increase. So, pour point depressants are unnecessary and higher viscosity basestock fluids can be used which will still meet the "W" requirements for pumpability.
Hence, little or no VI improver additive would need to be used to meet the sae 30, 40 or 50 classification while still meeting 0W or 5W requirements.
The end result is that very little shearing occurs within true synthetic oils because they are not "propped up" with viscosity index improvers. There simply is no place to shear back to. In fact, this is easy to prove by just comparing synthetic and petroleum oils of the same grade.
Of course, the obvious result is that your oil remains "in grade" for a much longer period of time for better engine protection and longer oil life.
If you would like advice then please feel free to ask.
Guy
Post #230064 Wed Jul 08 2009 1:46pm
Guy, given this is your area of expertise what's your view on the supermarket vc branded fuel argument?
Post #230066 Wed Jul 08 2009 1:51pm
Bobby
Phew!
I need to lie down after reading that!! Shocked Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #230073 Wed Jul 08 2009 2:42pm
Jonty
Location: Sat with my head in my hands wondering what the hell I'm doing
thank you Guy, most informative Thumbs Up Bow down Thumbs Up Bow down Current: I can't say...Oh the Shame!
Gone: 2003 Audi S4 - 340BHP of Fun Smile
Gone: 2005 RRS SE, Silver, Chrome Mirrors, Tinted with a stupid spare wheel!
Gone: Audi A4 2.5 TDi Quattro 180bhp
Gone: BMW 535i
Gone: 1985 Audi Quattro Sad Sad
Gone: Subaru Imprezza Turbo (rubbish)
Post #230075 Wed Jul 08 2009 2:57pm
RANGE_LOVER
Oil rules Thumbs Up
Post #230085 Wed Jul 08 2009 4:00pm
oilman
Site Supporter
To be honest I dont know enough about fuel to really make an educated comment. Last time I spoke to someone on the fuel side of things they said that different additives are used in the fuels. But what that really means I dont know.
Guy
Post #230086 Wed Jul 08 2009 4:07pm
Cornelius Vermuyden
Guy,
I aways read your company's website with great interest and would consider it the ultimate tribological resource(!) Similarly your comments on other forums. However, I think you are being just a little alarmist with the opening paragraph of this thread, factually accurate though it is. Unlike on the Scooby forum, where I saw exactly the same post, UK members here are unlikely to take their RRSport on track days or drive particularly fast on the road (even though I have no doubt they think they do!) Thus with the relatively mild upgrades available, petrol and diesel, the manufacturer's recommended oil is perfectly safe to continue using.
Ideally, of course, they should be educated to use a better oil in the first place, modified engine or not. Experience over 30 years has shown me that this is rather difficult. My company used and recommended only Motul synthetics for road and race (we even filled the Gemini bottles with 300V when we were sponsored by Shell!!) yet customers complained that they had never heard of it, or that it was only available in motorbike shops, or that is was expensive. The present company whom it is known I now assist use Castrol Magnatec; we have never had an oil-specific engine failure in any "chipped" Land Rover product, period. Nonetheless, if it was within my remit, I would still insist on using Motul products, but I wouldn't hold my breath!
Regards
Colin.
Post #230119 Wed Jul 08 2009 10:33pm
