Home > Technical > How do the front lights work?
dazsear
You want to try driving at night in heavy fog, the light movement is nothing less than hypnotic!
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #225903 Mon May 18 2009 6:30pm
gianluca
Italy 2006 Range Rover Sport TDV6 HSE Java Black
shmoogle wrote:
Having checked the specs the cornering lamps are included as long as you have xenons... in the UK, you have Xenons as long as you have an SE or above. The lowly S still gets halogens as standard Shocked
Seems you do not need the adaptives to get the cornering lamps Thumbs Up
Just the same here in Italy.
Well, so they must be cornering lights, according to what most of you say.
Whee is this lamp located, though?
Just curious to see it.
The car is currently stored in the garage and I will use it next weekend, so I Will have the chance to find this only after that.
Maybe I will try in front of a huge mirrir, trying to to turn just into it... Mr. Green
Post #225905 Mon May 18 2009 6:44pm
gianluca
valerio wrote:
ciao Gianluca,
non credo tu abbia i fari adattivi,peraltro non previsti sul sei cilindri.
si tratta semplicemente di una lanpada ,non xenon che si attiva a tempo
quando inserisci l'indicatore di direzione sotto i 40 km/h, superati
i quali la centalina esclude che tu stia svoltando ma che invece stai sorpassando
pertanto non accende niente.
cia'
valerio
Grazie Valerio, infatti č come pensavo .. figuriamoci se in Italia ti vendono un adattativo e non te lo fanno pagare per oro ..
Magari puņ succedere il contrario... Laughing
Post #225906 Mon May 18 2009 6:46pm
C10KO
They are located right next to your side marker lights, mate Whistle
Post #225915 Mon May 18 2009 7:41pm
4wheeldriver
Scotland 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Aye Ive got them and that was the question I asked salesman. But he said there wasnt xenons on the car. Im confused now as I KNOW Ive got cornering lights but dont know if Ive the adaptive xenons, standard xenons or halogens............ Cant even check the cr itself til it arrives a week Wednesday............ Big Cry Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
535d m-sport Platinum grey and a few extras.... Gone
X5 3.0 sd in Space Grey, 20's, Dynamic Pack, Memory Pack, Media Pack, Tow Pack, Rear DVD, Panoramic Sunroof, Steps, 7 Seat Pack, Reversing Camera with moving lines, programmable park heat, etc etc etc - Gone
Range Rover Sport Santorini, privacy, dvd, towpack GONE!!!
Post #225917 Mon May 18 2009 7:51pm
What model is your RRS? If you have Xenons (you'll easily be able to tell due to the crisp blue tinge of the lights), then you have cornering lamps. My earlier post was misleading - they don't only come with the adaptive lights, you get them as long as you have Xenons (which you will do if you have an SE or above).
Clear? Wink
Post #225951 Tue May 19 2009 7:21am
MAW
Depends on MY though doesn't it? I am sure my 55 HSE did not have cornering lights Confused
Post #225962 Tue May 19 2009 9:24am
4wheeldriver
Clear? Wink
S
Its the MY09 Stormer tdv6. Was told it was halogens in it but it DOES have the cornering lights. Thats what the salesman told me anyway and it does have the lights at the side that you spoke about. Thats why Im confused by it all. Worst bit is I dont pick it up for another week so I cant just go sit on the driveway and have a look. lol Oops I should have added that it does have the Clear View Pack fitted to it. Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Post #225994 Tue May 19 2009 12:14pm
gianluca
Ok gents, I got it.
Basically there are two additional halogen lights in the headlights which automatically turn on when you have lights on, the indicator on, and you are turning.
This is the bulb I am referring to.
Do you all have them?
Or is it just an HSE feature?
Post #227475 Sun Jun 07 2009 2:42pm
4wheeldriver
Thats the same light units that I have but I cant seem to ever see the cornering lights come on at all!! Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Post #227499 Sun Jun 07 2009 8:09pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
If anyone is still confused about what type of headlamps are fitted. i.e - Xenons or halogens. Lift the bonnet and have a look. On top of the headlamp unit there should be a label which will say if the light is Xenon or Halogen. Early models even have a warning label fitted because of the high voltage generated by the Xenon units.
Post #227505 Sun Jun 07 2009 11:05pm
gianluca
...although the Kelvin gradation differences between both should be quite clear. My gallery: http://www.rrsport.co.uk/gallery/thumbnails.php?album=994
Post #227557 Mon Jun 08 2009 2:53pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
you dont need to be indicating for them to work...
Post #227589 Mon Jun 08 2009 10:25pm
