Home > Maintenance & Modifications > fitting brembo's
kedz
United Kingdom 2009 Range Rover Sport TDV6 HSE Alaska White
fitting brembo's
rite got the caliper's got the disk's got the pad's do i need out else? someone mentioned back plate's??
Post #225126 Tue May 12 2009 11:34am
R33
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Yes you need the disc back plates, they are cheap any easy to get from a LR dealer. I got mine in 24hrs from CHPR. You might also need the Brembo brake wear sensor easily bought on eBay or from a dealer. Then you should be good to go.
Post #225130 Tue May 12 2009 1:47pm
kedz
thank's for the info mate Thumbs Up
Post #225181 Tue May 12 2009 10:31pm
Jonathan
England 2012 Range Rover Sport SDV6 Autobiography Fuji White
Kedz
Just had my brakes replaced by the stealer in Leeds however wasthinking that it would be good to have some of those nicve shiny red brembo's rather than dull grey -
Did you fit grey or red? Also - seems to me that the grey part is just a cover rather than anything functional...if so can you swap them?
You may not have the answer so may start a new topic if not.
Jonathan Jaguar XKR Convertible
MY 2012 Range Rover Sport TDV6 Autobiography in Fujian White....Mmmmmmm
Range Rover Evoque 2.2 Prestige in white - gone
Porsche Boxster S White with lots of extras! Gone
Lotus Elise 2011 Touring for sunny days - gone!
Previously....
RRS TDV8 Black 57 Plate
645ci
Jag XKR Convertible (my wife still loves this car!)
BMW 530i
BMW 328i (I loved this car)
Golf R32
Post #227737 Wed Jun 10 2009 1:01pm
R33
Mine are gloss black so they look a little more bling Wink
The grey part of the caliper that says Brembo on it is the main body of the cast caliper so is not a changeable part without swapping the entire caliper.
You could paint them with caliper paint and apply a new Brembo transfer but personally I would leave them well alone.
On the plus side though the braking power is an awesome improvement isn't it? Cool
Post #227742 Wed Jun 10 2009 1:56pm
Jonathan
Liking your gloss black idea but not going to mess with mine til they need replacing again - agree the braking is 2nd to none.
thanks for the response.
jonathan Jaguar XKR Convertible
Previously....
645ci
BMW 530i
Golf R32
Post #227782 Wed Jun 10 2009 9:47pm
R33
Just looked at the spec of your car for the first time and I'm a bit confused
I though TDV8's only came with Brembos as standard???
Post #227794 Wed Jun 10 2009 10:49pm
Jonathan
Yep - it has but they are the grey ones with black writing and I want RED!!!
I was thinking you could just change the outer shell as I have just had all brakes replaced but it doesn't look like they have changed the grey painted part..... Jaguar XKR Convertible
Previously....
645ci
BMW 530i
Golf R32
Post #228003 Fri Jun 12 2009 2:03pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
They make a great D3 upgrade too..... Very Happy Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #228017 Fri Jun 12 2009 9:04pm
Adam RRS
are the range rover and the range rover sport ones the same?
seen some on the bay of e WINNER - 2009 Best in Class Range Rover Sport Award
MY14 Corris Grey RRS HSE SDV6
Post #228018 Fri Jun 12 2009 9:07pm
simonsi
I´ve not compared but have seen some comments that they may be subtly different.... Cheers
Simon
Post #228029 Sat Jun 13 2009 8:09am
R33
Nope they are not compatible with the RRS and there are several different types for the the L322.
Post #228043 Sat Jun 13 2009 2:36pm
Adam RRS
also i heard if you upgrade from standard TDV6 calipers to TDV8 brembos, you need to change the hubs too. is this true? WINNER - 2009 Best in Class Range Rover Sport Award
Post #231632 Thu Jul 23 2009 10:12am
