Home > Maintenance & Modifications > Aux. Driving Lamp. |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 |
Hi, Is there anyone has DIY fitted the Aux. Driving Lamp? I've fitted one to mine correctly as instruction but didn't work. |
Thu Apr 30 2009 12:51pm |
You need to get the dealer to program the ECU to accept it. ISTR If the light on the button works it means you've installed the kit correctly. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Apr 30 2009 2:55pm |
Thanks, I'll go down to the dealer and have it done. |
Thu Apr 30 2009 9:40pm |
FAT_RRS Member Since: 18 Jun 2008 Location: COLORADO Posts: 98 |
Are we talking about the extra LR off road lights? |
Fri May 01 2009 3:49pm |
No, the twin pot light fits to replace the fog light on the front bumper. |
Fri May 08 2009 3:07pm |
Hi all, I was down to the BEADLES (Sidcup) today to have the ECU turns on the Aux. lights. After 40 mins., the service rep. came out handed me the bill of £80+VAT (£92) and said all done, lights ON. I believed everything was fine as it was such an easy work. Came home checked it & found out NOTHING worked. Came back to the BEADLES told the guy that it did work. He came out switched on the engine and turned the main light switch on and pulled it out then went to the front showing me the two fog lights ON. In complete sock, I told him those was the original fog and the others supposed to be ON. He then drove the car into the workshop for a moment and came out telling me .........
Fri May 08 2009 3:19pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
I have the Aux lights fitted to mine, they only come on when you are on high beam and have switched them on, the front fog lamps comes on when you pull out the light switch to the first position, rear fogs come on with the front fogs in the second position. Sons of dogs come hither and get flesh
Fri May 08 2009 4:38pm |
