![]() | Home > Technical > Mounting the Hitch |
Jeffrey Member Since: 03 Feb 2006 Location: California, USA Posts: 23 ![]() ![]() ![]() |
I tried to familiarize myself with the trailer hitch installation today. I couldn't even get the key out of it while still on the floor of my garage. I think the key allows rotation of the plastic part, but nothing was going anywhere, and the key did nothing. I have no directions for it. How hard could this be? Thanks for any advice. '06 RRS Giverny/Alpaca
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
Yes, it's all in the documentation... including instructions for the "hitch receiver" that we use in North America. |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
With the hitch off the car, it should be in the correct position to slot straignt into the car. The knob will then click into the closed position to allow you to lock it and remove the key.
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
The key does not remove until the hitch is secured in place on the car, you then lock with the key and remove. L319 D4 HSE
Yeah....I forgot that bit |
Thanks, guys. I appreciate the advice. '06 RRS Giverny/Alpaca
