Home > Technical > pdc module location anyone?
colintks
Hi guys,Can anyone tell me where the pdc module is located.I've had a problem with pdc on front for a week now, Crying or Very sad cleaned sensors front and back still playin up,got a new module off ebay so will try it before I take it somewhere.Don't want to spend big money if It's just a plug in replacement as I know it's a bumper off job if it's one of the sensors. Black on black 55 reg supercharged grill-vents black badges and 20" supercharged alloys with hankook tyres.
Post #219164 Tue Mar 24 2009 1:33pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
It's on the LH rear quarters of the car, behind the side trim panel in the trunk/boot. It's a small rectangular module attached to the frame with 2 retaining screws and with 3 electrical connectors on the bottom, should be in plain sight when you remove the trim panel. It's one of the few electronic modules in the car that should not require software uploads, diagnostics, programming and exorcisms after you hook it up, it should be "plug and play"... Thumbs Up Good luck, hope that's your problem! The "good" module (an early version on MY05s and some 06s had software that would cause the sensors to activate every time speed would fall under 10mph, causing a ton of false alarms at stoplights and intersections) should have part # YWC500550 stamped on it.
Post #219258 Tue Mar 24 2009 10:38pm
Bobby
umbertob is right. The earlier modules gave lots of troubles and a TSB was issued in mid-2006 recommending replacement of a 'modified' module. This might help further...
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #219262 Tue Mar 24 2009 11:08pm
umbertob
Hey Bobby, I think that removing the side trim panel is more involving than replacing that module... Laughing Do you have directions for that? Thumbs Up
Post #219263 Tue Mar 24 2009 11:14pm
Bobby
Yes, umbertob, quite a bit of work involved! Laughing
Here you go...
http://www.rrsport.co.uk/gallery/albums/us...0Panel.pdf Malaysia Boleh!
Post #219270 Tue Mar 24 2009 11:45pm
colintks
Thank's guy's,stripped the car down today.Exchanged the module but still playin up, Crying or Very sad .looks like a trip to stealers Big Cry Now have a spare module but for the price I paid for it I'll keep it.
Will post what they come up with. Black on black 55 reg supercharged grill-vents black badges and 20" supercharged alloys with hankook tyres.
Post #219642 Thu Mar 26 2009 2:13pm
umbertob
Bummer. If it makes you feel any better, I am having the same problem with one of my rear PDC sensors, although I know exactly why it's starting to act up - it's my fault for removing the tips off my Overfinch exhaust when I go off-roading and then being too lazy to put them back on when I get back. The hot gases from the shortened exhaust ends are causing the two sensors in their proximity to slowly "melt" (as well as a portion of the lower bumper...) Embarassed
Post #219678 Thu Mar 26 2009 3:30pm
Bobby
Hey umbertob, was the directions to remove the side panel satisfactory? Wink Malaysia Boleh!
Post #219773 Thu Mar 26 2009 11:32pm
