Home > General > Ball Joint replacement ?
monkey9952
Just had car serviced and Mot , Dealer said that the Ball Joints need replacing as there is a lot of play in them. Has anyone had this ? also should this be under warranty , they say its wear and tear ?
Post #217275 Sat Mar 14 2009 8:42am
Red1903
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
My car was in Wed/Thur to have a few problems sorted out. All work was covered by the warranty including the ball joints being replaced. Take the car to another Dealership that will do the work under warranty.
How old is the car?
Post #217288 Sat Mar 14 2009 9:31am
Misery
1st MOT?? if so then I would seriously try getting in touch with LR customer services as I have had 3 sets of ball joints already, my little lovely has just turned 3 years old. Good luck. Thumbs Up Thumbs Up
Post #217289 Sat Mar 14 2009 9:33am
monkey9952
Thanks for the replys , its an 06 , First mot , i asked if it was a warranty thing , they said wear n tear so no ... hmm i will take it up with them again problem is is that the warranty expired while it was with them and is still with them.
Post #217297 Sat Mar 14 2009 10:06am
Misery
No don't stand for it, if it was there befroe the warranty expired they need to fix it under warranty. Wear and tear my bottom. Shocked
Post #217308 Sat Mar 14 2009 11:09am
monkey9952
Thanks for your comments Misery , i ve just been to pick it up they still insist that the ball joints are not a warranty item , so i think ill have to take it further Banging Head
Post #217342 Sat Mar 14 2009 2:49pm
Misery
You do that kick arse. Thumbs Up Thumbs Up have you ever mentioned the knocking noise to them??.
Post #217346 Sat Mar 14 2009 2:55pm
monkey9952
I have never suffered from the knocking noises that have been reported , i would have thought for them to say they are worn etc that i would have some idea that there was a problem i.e knocking and the like but i havent noticed anything apparently wrong with the drive so maybe they are just talking Censored need to look into it further , take it to another dealer or try customer services like you said , obviously its not a major issue or it wouldnt have passed the mot.
Rolling Eyes
Post #217368 Sat Mar 14 2009 3:25pm
Tim in Scotland
Have you had a second opinion that you actually need to replace the ball-joints? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #217384 Sat Mar 14 2009 4:48pm
monkey9952
Not as yet Tim , but looks like i will need to.
Post #217386 Sat Mar 14 2009 5:04pm
rrsjo
If I remember correctly didn't Land Rover produce an upgraded ball joint due to the original item suffering rapid wear? I think Jock reported this in one of his past posts a few months ago. Regardless of whether I am correct about the upgraded part, your dealer should replace the ball joints under warranty, as the car was with them prior to the warranty expiring. It does not matter that the warranty has expired in the meantime. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #217388 Sat Mar 14 2009 5:31pm
monkey9952
Just need to find a dealer that agrees that it should be under warranty , they wanted £500 to do it Censored
Post #217434 Sun Mar 15 2009 7:46am
Josh
Yep there is an upgraded balljoint to replace the poorly designed one that kept breaking. It's a warranty job.
Since mine had the latest version there has been no rattling ball joints.
Just had new design bushes put on at the front. But they have to do the back this week........and then I'm hoping for peace and quiet Bow down Bow down Bow down TDV6 - gone
TDV8 - gone
Post #217453 Sun Mar 15 2009 12:29pm
rrsjo
Sorry Josh, but at least you knew who I meant. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #217456 Sun Mar 15 2009 12:34pm
