Home > General > Any advice on defrosting screenwash jets?
Red1903
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Paul stick in the screenwash neat like Tim says, try and find the gear thats good for minus 25 as thats whats in mine just now. Sure i picked some up from Dunecht 4 x4. If you cant get then give me a shout and i will go and pick some up for you Thumbs Up
Post #210680 Mon Feb 09 2009 8:43pm
Bobby
PA, don't you have heated jets?
http://www.rrsport.co.uk/forum/post203629.html#203629 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #210699 Mon Feb 09 2009 11:50pm
If all else fails, leave the Sport stationary engine running when warm. That'll thaw them out. Runner up - 2009 Best Avatar Award Sad
Post #210702 Tue Feb 10 2009 6:04am
PauloAmore
Scotland
Hmm. well, I should so. But they don't feel warm to the touch. 2022 P440e AB
Post #210709 Tue Feb 10 2009 8:54am
Tim in Scotland
They don't get that warm Paul. They are heated but not HOT! Another thing to try is to squirt some aerosol de-icer (kust a tiny amount) on each nozzle and leave it for a couple of minutes. Is the tank frozen or are the lines frozen?
ST - Paulo has an S/C - leaving it to warm up will cost about 1/2 tank of fuel - they don't have an FBH in S/C's IIRC............................. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210711 Tue Feb 10 2009 9:01am
PauloAmore
Scotland
LOL....
No idea what is frozen.....
I filled the bottle full of a pre-mix, now not sure that it was winter stuff, so reckon it is probably all frozen!
- Though at one point, the headlight scooshers worked....
PS - My SC 4.2 Engine is so efficient that the engine bay, oddly, doesn't get too warm. Really weird... 2022 P440e AB
Post #210714 Tue Feb 10 2009 9:10am
Tim in Scotland
It's because of this, and to reduce cold start emissions, that the TD engines have the FBH. The high carbon content engine block is so thermally efficient that in cold weather you don't get warm air into the cabin for a very long time without the FBH, which is set up to cut-in automatically when the outside temperature is less than 5C, it still takes time to heat the cabin with it running, just you get warm air within 2-3 minutes instead of waiting hours. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210717 Tue Feb 10 2009 9:17am
Tim in Scotland
I've just moved my car off the drive - all scooshers frozen solid and nothing coming out even after running the engine long enough to get warm air to thaw the ice on the screens. The water bottle isn't frozen as there is fluid water right up into the neck of the washer bottle neck. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210721 Tue Feb 10 2009 9:36am
Money Money Money
2005 Range Rover Sport Supercharged Java Black
Tried usuing my screen wash int he snow and nothing. Checked the fuse - Blown!
Can you hear the motor trying? If you cannot hear anything when trying then i'd check the fuse! (Which is bloody hard work)
Post #210767 Tue Feb 10 2009 4:33pm
PauloAmore
Scotland
OK....
but... I've owned the RRS for 2 years.... And have never seen the fuse box....
Where is it?
- Go easy on me gents though I expect to hear R T F M! Big Cry Big Cry Big Cry 2022 P440e AB
Post #210768 Tue Feb 10 2009 4:39pm
Tim in Scotland
Checked the Halfords screen wash I have today - instructions give dilution directions and they say that neat liquid has strong enough antifreeze to work down to -15C. 50% is ok down to -5C. I think part of the problem is that the front screen washer lines run between the steelwork and the under-bonnet insulation so you are on a looser even with the nozzle heating as the insulation also stops the engine heat from getting to the lines and the steel will be freezing them too.
In 1982 I remember having a long period of temperatures that even in my garage went down to -20C. Even the neat screen wash froze and the washer tank didn't thaw out even after a 19 mile drive into town and sitting in the rush hour traffic. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210783 Tue Feb 10 2009 5:57pm
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
XXXAngelXXX wrote:
Red1903 wrote:
My RRS sits outside all the time and the jets have never stopped working even when its as low as -12*C.[...]
+1 ! Thumbs Up
+1! Very Happy
(Althoug usually parked in the garage but I didn't have an issue when it was parked in the mountains for two days at -18. Cool
As to answer the original question:
Buy a garage, park the RRS inside it for one day, done! Thumbs Up Mr. Green RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #210838 Wed Feb 11 2009 9:50am
