Home > Australia & New Zealand > Suspension Knock
BT
Australia
Suspension Knock
I purchased a RRS TDV8 in July 08 at 1200KMS it developed a suspension knock. Dealer changed bushes and DR pump and the knock still occurs. Pulled fuse to dynamic response system and the knock is still there. Any one got any idea of a fix???
Post #209273 Sat Jan 31 2009 9:26am
baxc
hi bt is the knocking coming from the front when you go over a bumpy road or a pothole
Post #209277 Sat Jan 31 2009 9:56am
Josh
Now a common problem.
Get your dealer to follow the latest TSBs issued by LR and fit new design ball joints and new design AR bushes.
No guarantees but it's a step in the right direction. TDV6 - gone
TDV8 - gone
Post #209286 Sat Jan 31 2009 11:25am
BT
Australia
Gday baxc. The Knock comes from the front in the right but occasionally occurs in the left. It accurs when I hit some rough road. It is shocking off road and sounds as though a stut is broken. Would not want to go to far off road.
Post #209393 Sun Feb 01 2009 1:10am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
BT - there are quite a few threads on these issues outside of the Australia and NZ section if you do a search. Hope they manage to fix yours soon! let us know how you go with your local dealer!
Post #209394 Sun Feb 01 2009 1:24am
2nd Rower
Try reading up on this post BT, there are some others as I said if you do a search on the forum:
http://www.rrsport.co.uk/forum/topic7227.html
Post #209397 Sun Feb 01 2009 2:43am
baxc
hi bt it sounds like the same problem as mine it needs new anti roll bar bushes lr do a new modified 1 now and new ball joints had mine done 2 weeks ago under warranty nocking has completly gone now hope you get it sorted m8
Post #209407 Sun Feb 01 2009 11:25am
BT
Australia
Just a quick update on my RRS TDV8 suspension knock. Took car to another dealer for second opinion. Dealer upgraded software and re adjusted rear door (another matter). Was not impressed with the update so I took the car for a run to the Pilbara and put it through its paces on the access roads to the Georges and surrounding tracks near Tom Price and out onto the Burrup peninsula. The knock still occurs in the right front (clunk some times) but is now over shadowed by the the rear door that rattles so badly that it sounds as it may fall off (cant win). I wonder if its possible to shoe horn that lovely TDV8 into a X5. Laughing
Post #217435 Sun Mar 15 2009 8:52am
