Home > Technical > Blinker Relay... Help please!
antics22
United States
Does anybody know where the blinker relay is located in the RRS? I looked in the fuse panel behind the glovebox and found no relays... I also looked under the steering wheel panel (under the footwell) and could not locate it either....
Does anybody also happen to know if the relay is a 5-pin, or 3-pin?
thanks in advance!
Post #11479 Fri Jan 27 2006 6:20am
Bobby
Did you try the fusebox in the engine compartment? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #11480 Fri Jan 27 2006 6:48am
PaulB
I suspect there isn't an actual relay. The sound you hear when using the "blinkers" isn't a relay, it's a digital sound.
The sound is suppressed if the navigation or telephone cuts in.
Paul RRS TDV8 - Stornoway Grey, Irory Leather with Dark Zebrano, Privacy Glass, Tow Pack.
1967 Cobra 427 S/C
1951 Vincent Comet
2001 Harley Davidson Fat Boy
Post #11481 Fri Jan 27 2006 8:31am
antics22
United States
Well, looked under the hood (bonnet for you uk folks!) and looked at the fuse box, no signs of a relay for the blinkers... there were plenty of relays there for other things, but no blinkers.... any other ideas?
PaulB, the sound IS coming from the dash, but there has to be a relay to make the blinkers work.. .right???
PS. to recap, I have checked behind the glovebox, under the bonnet, and under the steering wheel...
Any help is appreciated!
Post #11684 Mon Jan 30 2006 9:47am
Martin
Site Administrator & Owner
I think the indicators are probably driven by a body control ECU instead of a flasher relay - GTR will tell you for sure Wink Like this site? Buy some RRSPORT goodies to show your support!
Post #11685 Mon Jan 30 2006 9:49am
Martin
As suspected, it's electronically controlled internally to the Central Junction Box. The indicator switch and hazard switch only provide switched earth signals to it Sad Like this site? Buy some RRSPORT goodies to show your support!
Post #11687 Mon Jan 30 2006 10:32am
PaulB
As I said, its all digital. The sound you hear, which would normally be the relay switching, is actually a digitised "impersonation" of the relay.
Why did you want to get at the relay ?
1967 Cobra 427 S/C
1951 Vincent Comet
Post #11699 Mon Jan 30 2006 11:49am
vesurover
United States 2006 Range Rover Sport Supercharged Vesuvius Orange
Antic did you put in led turn signals?
Post #11772 Mon Jan 30 2006 11:18pm
antics22
United States
Thanks for the information guys.... Yes Vesurover, I started experimenting with LED's and wanted to replace the relay with a heavy duty electronic one... but looks like I am out of luck and have to go with the resistor(s) alternative instead....
will update with pics when I am finished with my lights.
Post #11773 Tue Jan 31 2006 1:40am
antics22
United States
Martin, thanks for looking up the blinkers on the GTR site...
I am not quite ready to give up yet... there has to be a blinker module in our vehicles somewhere that handle the blinking, and different loads for our blinkers though, right? WOuld the GTR site show where this module might be? any help would be appreciated...
PS. on a side note, I have been successful at modding my front headlights and removing the amber portion of the front... so now, I am just finishing up some LED replacements to make everything more "modernized"
heres a preview... I will post step by step instructions on this once I am done as I am documenting all my steps!
Post #11780 Tue Jan 31 2006 8:45am
tasmod
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
Post #11785 Tue Jan 31 2006 9:01am
antics22
United States
Thanks Tasmod, I will check there tomorrow morning! Its 1am here in the US and I have lost ALL track of time trying to research this online... Will update with my findings. Smile
Post #11788 Tue Jan 31 2006 9:05am
Hi antics22,
I do like the new front lights now they have been modified to remove the amber strips - looking forward to your step by step instructions Smile
Post #11790 Tue Jan 31 2006 9:10am
