![]() | Home > Technical > From 70mph to 5 mph on the motorway! |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
Hello RAD ,
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
Kam had this but he lost all power restart and it was ok! RRS TDV6 Gone but still around
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 ![]() ![]() ![]() |
Exactly that happened to me a few years ago, driving the 2002 Freelander TD4 (with the BMW motor), and it turned out to be the fuel injectors.
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
sucks |
It's been reported a small number of times on here... could've been pretty dangerous. Take it to the dealer and let them know how you were nearly killed - they should pay attention |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Rad,
RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309 ![]() ![]() ![]() |
The simple answer was............mucky fuel filter, every time I floored the throttle, the necessary amount of fuel didn't get through and the management system decided it would be best to go into limp mode!
Do you buy your fuel from the same place all the time - might be worth taking it up with them if you do. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Marc31 Member Since: 04 Mar 2008 Location: Lancashire Posts: 73 ![]() ![]() |
Yea i've been having this problem for the past month or so too!!
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I had similar once on the last RRS - was a throttle sensor on the accelerator pedal |
Just like I said , Bob
vipah2002 Member Since: 29 Jan 2009 Location: Scotland Posts: 2 ![]() ![]() ![]() |
This happened to me, on the day I picked up the car 17th Dec 2005, nearly kiiled my whole family as we lost power on a round -a bout, we had stopped twice on this wholly moterway journey as we had the full dash full of lights....the car was returned to LR on the 19th when we return home, it did the same on the return journey, fail..then drive ok then you would loose power again without notice, LD took the car back and I did not seemy new moter until the 24th Dec....
jk516696 Member Since: 15 Mar 2006 Location: uk Posts: 17 ![]() ![]() |
So finally the snow came and I was looking forward to some fun in the RRS. |
I took mine in on the 5th of February for this very same fault. They said it was the gas valves so replaced them, finally got it back on Friday 13th (after problems with the Courtesy car too |
