Home > Technical > Is there a link between air temperature and fuel economy?
Tim in Scotland
Since I came home on Sunday the trip computer on my TDv8 has been showing mpg's varying between 30.0mpg and 36.5 (that's the best I have ever seen and it was averaged over 16 miles on a flat road at 60mph). Normally I only see over 30mpg after driving all day at 70 on the cruise, not in A road driving with speed variations and other traffic when I see between 26 and 28mpg depending on how I drive the car.
Now I can put this down to only 2 things:
a) It has been pretty cold around here - day time temperatures not above +5C
b) My Trip Computer is having a seizure
Theory a) If the ambient air temperature is low then the intercoolers are not having to do so much air cooling for the charge air or they can cool much larger quantities of air so I am burning more air in the mixture than normal thus making the engine more efficient.
Any automotive engineers care to give an explanation of why my fuel economy is so much better in cold frosty weather than warm days? Bear in mind that as a result of the cold weather I am using things like the seat heaters, screen heaters, interior heater and FBH much more than normal and these all put a big load on the engine and should increase fuel consumption rather than reduce it. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #207800 Fri Jan 23 2009 9:11am
Does this help Tim?
http://www.articlesbase.com/cars-articles/...41281.html
Post #207818 Fri Jan 23 2009 9:53am
MAW
The article is opposing Tims findings then... Rolling Eyes
Post #207821 Fri Jan 23 2009 10:03am
Looks like it... several Google results seem to all point to the same fact Smile
Post #207823 Fri Jan 23 2009 10:05am
Tim in Scotland
Maybe the cold, more viscous fuel taking longer to get to the engine is fooling the trip computer that it is burning less Rolling with laughter 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #207835 Fri Jan 23 2009 10:30am
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Or you are drinking something to warm yourself up early in the morning and are not reading the carputer correctly.... Mr. Green Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #207850 Fri Jan 23 2009 10:55am
Tim in Scotland
Or.............................. the oil majors add dewaxing agents to diesel in the winter and my car rather likes it! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #207938 Fri Jan 23 2009 1:54pm
jmm
France 2008 Range Rover Sport TDV6 HSE Tonga Green
Or you're not using the air con.
I noticed that using only the heater (ECO) reduces my consumption by 1/1,3 l/100km
Post #208117 Sat Jan 24 2009 4:42am
Killerbob
Switzerland 2009 Range Rover Sport TDV8 HSE Java Black
I saw the same thing happening as Tim, and then realised that I had not added my usual 400ml 2-stroke oil into the diesel, last time I filled 'er up. Embarassed
Duh!
KB RRS TDV8, black with ivory.
Post #208126 Sat Jan 24 2009 8:24am
bex
Never believe your trip computer Crying or Very sad
Post #208141 Sat Jan 24 2009 10:23am
C10KO
KB, do not mind me asking by why the hell do you put 400ml 2-stroke oil into the diesel?
Post #208150 Sat Jan 24 2009 11:47am
Killerbob
Coko,
It has all been discussed before; http://www.rrsport.co.uk/forum/topic10453.html?highlight=2stroke
In essence, by adding high quality (JASO C or D), semi-synthetic, 2-stroke oil, in a 1/200mix, to your diesel, you get a better burn, especially in cold climates. It mixes with the diesel, lubricates the engine, and has a better burn, resulting in 5-7% better driving economy, easier cold-starts, less smoke, and a more quieter motor.
I have used this since I got the TDV8, and even long before, in my diesel Volvo Penta Z-drive boat engine.
Post #208175 Sat Jan 24 2009 1:35pm
Red1903
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
I remember a tuner explaining that Turbo Chargers operate much more efficently in colder weather. When I had the RS4 on the rolling road they chilled the air in front of the car as the workshop was very warm, to get a realistic dyno graph. Not sure if more efficent turbo chargers equates to better fuel consumption or not Confused
Post #208738 Wed Jan 28 2009 12:15pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
One of the reasons my Scooby STi had a water-spray bar over the turbo intercooler as using it could give you an extra 10% or more power Sons of dogs come hither and get flesh
Clan Cameron
Post #208740 Wed Jan 28 2009 12:22pm
Gary
Ambient air is more condenced the colder you get, most Diesel and Petrol engines will run better in these conditions as more air is forced into the chambers making the Engine more efficient, thats why most engines appear to have better performance in damp or wet conditions (natural air cooling and condensation)
Post #208750 Wed Jan 28 2009 2:32pm
