Home > Maintenance & Modifications > Front armrests dropping
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
Our front passenger seat armrest keeps dropping down so it is resting on the centre console and the leather makes a constant squeaking on the cherry wood trim. You can then turn the adjuster to put the armrest pack to the correct position, but then in about two days time it is back resting on the centre console again.
Has anyone else got problems with their armrests? I suppose the plastic adjuster screw mechanism is problem, but I wouldn't be surprised if this turns into a major job to fix it. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #11340 Wed Jan 25 2006 11:29am
Mine used to do that too, until I got fed up with it and decided I preferred to rest my arm on the centre armrest anyway. I think I thought the same as you Matt, if I take it to be fixed am I going to be without it for 3 days while they decide how to put it back together again....
Post #11343 Wed Jan 25 2006 11:33am
PaulB
I had what appeared to be a similar problem. The armrest was in the correct position, but if any pressure was put on it, it would drop.
The problem turned out to be that the armrest wasn't actually "resting" on the adjuster, but on the edge of the central console and if any pressure was put on it, it would fall off the edge.
The solution was to turn in the adjuster so that the arm was resting on that rather than the console. Someone had turned the adjuster down too far beyond the lower level of free movement for the arm.
Does that make sense ?
I hope this helps.
Paul RRS TDV8 - Stornoway Grey, Irory Leather with Dark Zebrano, Privacy Glass, Tow Pack.
1967 Cobra 427 S/C
1951 Vincent Comet
2001 Harley Davidson Fat Boy
Post #11345 Wed Jan 25 2006 11:36am
d3matt
It sort of makes sence PaulB, but then I have adjusted the knob so that the armrest is high (too high), but then over two days it slowly falls back down until it is resting on the centre console trim. Matt
Post #11358 Wed Jan 25 2006 12:32pm
PaulB
Mmmm....doesn't sound like the same problem does it Confused
Good luck.
1967 Cobra 427 S/C
1951 Vincent Comet
Post #11365 Wed Jan 25 2006 1:31pm
This is not something I've come across - it sounds like a faulty nut or something. 2005 Zambezi TDV6 - Gone but not forgotten
Post #11367 Wed Jan 25 2006 1:45pm
d3matt
Are you talking about the owner or the armrest? Matt
Post #11370 Wed Jan 25 2006 2:14pm
Now I try and be serious for once and am I get is abuse Crying or Very sad Crying or Very sad Wink 2005 Zambezi TDV6 - Gone but not forgotten
Post #11371 Wed Jan 25 2006 2:18pm
Bobby
Very Happy Very Happy Laughing Laughing Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #11429 Thu Jan 26 2006 4:28am
