Home > Technical > DSC... |
Korenai Member Since: 05 Oct 2008 Location: Lugano Posts: 244 |
So, we had some snowy days here in Lugano, and since my Contis are worn, sometimes driving in snow wasn't really easy. Terrain Response on snow and shifting to low range gears was ok, but then I recall the manual saying something about the DSC on slippery ground...
Thu Dec 11 2008 3:26pm |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 |
I would say that is when you want DSC. You can't turn it completely off anyway. It detects if the car gets out of shape and backs off the throttle and gently brakes bringing the car under control. The only time I switch it off is muddy conditions off road Porsche Cayenne S Diesel 66 Plate |
Thu Dec 11 2008 3:50pm |
As Pelyma said - here's the LR garb.
Thu Dec 11 2008 3:59pm |
Ah ok, so it's mainly for stability during turns... Thanks! |
Thu Dec 11 2008 5:15pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
"Terrain Response on snow and shifting to low range gears "
Thu Dec 11 2008 7:51pm |
Works in high or low ratio. It depends on what the ground is like as to which ratio you might choose. If it is easy gravel type tracks then high would be fine, wet grass on an incline then low would be better. HTH Porsche Cayenne S Diesel 66 Plate |
Fri Dec 12 2008 9:17am |
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 |
On snow is better to drive without DSC... more fun, you can improve your driving/drifting skills RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
Fri Dec 12 2008 9:34am |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
especially with Conti summer tires...
Fri Dec 12 2008 9:49am |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 |
The brave men do not need winter tyres or DSC!
Fri Dec 12 2008 10:11am |
I have Pirelli Ice & Snow... but I need them, we often drive to mountains RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
Fri Dec 12 2008 10:22am |
Brave men need a roope asnd tractor though |
Fri Dec 12 2008 10:28am |
Downhill the car was going quite fast, and every time I touched the brake, it was sliding around... With low gears, the car was going slower and was basically gently braking by itself every time I lift the foot off the pedal, resulting in a much more safer stop... |
Fri Dec 12 2008 6:51pm |
That's why I am going to fit Pirelli Ice&Snow tomorrow.
Fri Dec 12 2008 6:54pm |
lespes wrote:
Fri Dec 12 2008 6:56pm |
