![]() | Home > Australia & New Zealand > brake pads replacement cost |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Cannot comment on the disk grind although i have heard it said at my old dealers that every other set it would need new disks |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
I was quoted 900 about 18 months ago with only 19K on the clock .. that was for Pads and Rotors which they have to change i believe. 2 months later when i booked it in, they did it for just over 600.. that was Alto at Artomon. Current pads have been on for 40K and were ok based upon the last service Cheers Jim Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
640Newton Member Since: 01 Sep 2008 Location: Sydney via Wolverhampton Posts: 231 ![]() ![]() ![]() |
Not sure I want to ask this but does anyone know roughly what it's going to cost when it comes to replacing the Brembo brakes on the TDV8?
redrover Member Since: 22 Jun 2007 Location: Sydney Posts: 94 ![]() ![]() ![]() |
Yeah, my quote was from Alto Artarmon as well but without a rotor change. Curious as how you got it for $600. Might have to ring around a bit. Does anyone know if you replace them yourselves wether you void the warranty? I would love to have some pads that don't create as much dust! TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
Well it had its 72K service, a pity it has only done 60K, and the verdict is:
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 ![]() ![]() |
I have just been quoted NZ$1047.00 inc GST to replace four rotors and all pads including labour on my TDV6. The sensor would be another 80 on top if it is damaged - but as the light is not yet on it should be reusable. |
Bargain i would say ![]() MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
I finally got all the pads done at 43000km with the light just coming on. I was originally told about $950 with a grind. When I dropped it off I was told the guy who does the grinding may not be back yet from holidays. I said I wasn't too worried if they weren't ground as I hadn't had problems in the past.
Couple of hours DIY even with the LR jack (painful). Scratch needs addressing |
I think it may polish out but annoying just the same. Trouble is they are a 10 min walk from work which makes it hard to vote with my feet. They were pretty good on the last couple of services as well. TDV6, MYO7 Java with Ivory leather, 19 inch wheels |
