![]() | Home > Maintenance & Modifications > Mid service interval Oil change |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
Had mine changed in our own workshop by our head fitter at 3000 miles and, still think one year or 15000 miles is too much currently at 8000 miles and will be doing it again soon. Its out there somewhere. Second V10 Treg on the drive at the moment. |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Do you think same theory applies to the SC version tho? L319 D4 HSE
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 ![]() ![]() |
I should think it'll apply to most engines, new oil can never be a bad thing.
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 ![]() ![]() |
Oil changes can never hurt. The real benefit of more than recommended oil/filter changes is debatable. Of course, the oil changing industry wants you to do it as often as possible. |
thebishman Member Since: 21 Dec 2005 Location: Kansas, USA Posts: 98 ![]() ![]() ![]() |
Do the Euro RRS's use synthetic oil? I ask because the US oil/filter change recommendations are at every 7500 miles, NOT 15K
I was told to use 5W30 fully synthetic oil, which over here relates to Castrol Magnatex.
The haulage fleet for the company I work for are on long drain oils with change intervals of 6 months but very high mileage. Its out there somewhere. Second V10 Treg on the drive at the moment. |
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
With the long service intervals on modern cars (due to the better oil technology), I've been a bit worried about the long interval of the first service on a new engine. On previous vehicles, I've done initial oil changes at around 7,000 miles.
good points. I was thinking similar. L319 D4 HSE
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
I'll probably change before a service is due |
going back to Audi? L319 D4 HSE
No ... NO....NO..
Excellent news |
Since the chassis of the Big RR is completely different and does not have dynamic response - I am sure the sport will continue to drive/ride better. |
