Home > General > Spare Key |
This is true they recharge in the ignition. Best to alternate between keys. Both of my keys go for 3-4 months without going near the car and I haven't suffered from a flat keyfob battery yet.
Wed Sep 24 2008 12:29pm |
mr boombastic Member Since: 08 Dec 2007 Location: NSW Posts: 40 |
Thanks Tim.
Wed Sep 24 2008 12:38pm |
There's one way to find out .................................... if it is totally flat then open the car with the other key and then use the key with the flattened battery for a few days to recharge it 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Sep 24 2008 12:43pm |
So even if the key is flat i can put it in the ignition and it will start the car and recharge itself? This is my first LandRover I'm not sure what to expect! |
Wed Sep 24 2008 12:52pm |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Tim's suggestion is correct. Even if both keys were flat you could still open the vehicle manually (via the passenger door handle) and then start in the normal fashion. James |
Wed Sep 24 2008 12:55pm |
IIRC the fob has a chip in it that the immobiliser recognises (if you have them on Aus spec cars) but it doesn't need any power for that. To use the emergency unlock on the passenger door you remove the small blanking plate/finisher that has the padlock moulded in it and underneath is a keyhole 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Sep 24 2008 1:02pm |
Thanks all! |
Wed Sep 24 2008 1:14pm |
