Home > Off Topic > IT geeks - What is WinRAR?
It's an artefact of the install routine that leaves these files behind and they are normally cleared away upon next reboot.
Alas, I don't use Spybot or Kaspersky so not able to have a play myself, but... this doesn't look right in the logs:
Quote:
Events
Event Object Name Time Traffic
Selecting update source http://127.0.0.1
That IP address is known as the loopback address and basically means "myself".... I'd expect that it should be updating itself from a source on the internet, but as I say I don't have the software so it maybe that it's proxying through something else? Is there a firewall installed on the PC?
Post #191116 Tue Oct 07 2008 11:51am
S, I found on the kaspersky website that there are a lot of viruses which use the HOSTS file to prevent the user from connecting to the anti-virus company site.
It says (With XP) to go to folder 'SYSTEM32/DRIVERS/ETC' and correct the file by deleting all the lines except 127.0.01 localhost ( Confused Confused Confused )
When I go into this folder, there are 6 files, none of which are accessible.
They are:
hosts
hosts.20081005-174756.backup
lmhosts
networks
protocol
services
As I can't open or access these i'm now stumped.
Trying to navigate the kaspersky hep site is nigh on impossible too! Big Cry Runner up - 2009 Best Avatar Award Sad
Post #191123 Tue Oct 07 2008 12:06pm
When you say they're inaccessible, what do you mean? These files don't have extensions (like .txt or .doc for example), but you can open them in Notepad and edit them from there Thumbs Up
Post #191125 Tue Oct 07 2008 12:09pm
Yeah, they don't have extensions.
Will try in notepad...
Thanks S Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #191127 Tue Oct 07 2008 12:11pm
F Censored K ME!!!!!
If there is only supposed to be one line in there, 127.0.0.1 localhost...
There is about a million and one!
AND it says underneath the above line
'# Start of entries inserted by Spybot - Search & Destroy'
Shal I delete all the other ones then? Runner up - 2009 Best Avatar Award Sad
Post #191129 Tue Oct 07 2008 12:13pm
monkey9952
I would Delete all entries associated with Spybot , save the file then reboot. Hopefully that will sort it.
Post #191152 Tue Oct 07 2008 2:37pm
Done all that! Evil or Very Mad
Now looks like I have to uninstall current version of Kaspersky (6.0.0.303), save activation details and download new version 8.0.0.545!!! Evil or Very Mad Evil or Very Mad
If that doesn't work, it's going the same way as my iPod!
(In the f Censored g pool!) Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Runner up - 2009 Best Avatar Award Sad
Post #191154 Tue Oct 07 2008 2:40pm
monkey9952
Might be the registry , there is a reg file you can download install and it cleans all spybot registry entries ... might help ?
Link here ,,,
http://www.safer-networking.org/files/remo...ttings.reg
Post #191156 Tue Oct 07 2008 2:43pm
Do the activation details work across versions?
A lot of hardening guides will suggest setting the hosts file to read only so it's less easy for other apps to hijack it. You might want to do this - in Explorer, right-click the file, select Properties and at the bottom of the dialog box select the Read Only check box and click OK.
By rights, now you've reset your hosts file to it's normal state you may well be able to update Kaspunky across the internet anyway, unless you've since uninstalled it of course Very Happy
Post #191161 Tue Oct 07 2008 2:49pm
Pelyma
Go on chuck it in the pool - then buy a mac Laughing Mr. Green Porsche Cayenne S Diesel 66 Plate
Post #191186 Tue Oct 07 2008 3:34pm
It is currently sat next to the pool awaiting a good dousing! Evil or Very Mad
Tried EVERYTHING I can think of and still isn't working.
I bought KIS 2009 for my work laptop and apparantly it is for up to 3 seperate machine installations. Looks like that is my only option left Evil or Very Mad Evil or Very Mad
Thanks for all your help and advice, some more constructive than others... (Pelyma! Laughing Wink ) Runner up - 2009 Best Avatar Award Sad
Post #191230 Wed Oct 08 2008 7:13am
Mate, you can fly me out to fix it for you if you like Whistle
Post #191247 Wed Oct 08 2008 9:31am
Was just about to book your flight....
.... when I tried KIS 2009 as mentioned in earlier post.
Seems that it was an internal fault with the KIS version 6.0 as now it works fine.
Crisis over.
Oh yeah, Shmoogle you can put your shorts and suncream away now but thanks for the help anyway Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #191276 Wed Oct 08 2008 12:01pm
Censored Wink
Post #191333 Wed Oct 08 2008 2:42pm
