Frosty_Power
Bobby wrote:flydive wrote:crowej wrote:flydive wrote:Go with an aftermarket product like Parrot, 10 times better than the LR one.
thanks, does that give you the option to dial via the radio ? or does the LR kit even do that ?
No the Parrot is a separate module, you select the contacts on it.
With the LR kit you can dial via the radio, kind of, you can select the first letter of the contact on the keypad but then you have to scroll through the contacts with the selection wheel(or the switches on the steering wheel).
What you do not get with the LR kit, at least with the Nokia 95 and for what i can see most of the headsets, are multiple numbers per contact, call history(dialled, received).
No, with the LR Kit you only get Bluetooth, Handsfree and Voice Recognition, which is useless! You cannot dial via the radio, although the radio will go silent during a call. No keypad use also!
Its not the same as the the factory fitted phone system.
Hmmm....I just purchased an '06 and was playing with the bluetooth last night to try and get my BB paired up. It pairs up and I can dial thru the radio with the keypad. It worked on my phone and the radio does go silent. I hit the green phone button on the steering wheel and type the number on the keypad, it was working great for me. Could not transfer contacts but thats been posted several times.
Thu Oct 16 2008 11:25pm |
