Home > Technical > Sounds like passenger side door not shut
Ste Sleds
2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi
Sat in the front passenger seat for the first time today whilst I let the other half drive, if that wasnt bad enough,
I noticed that it sounded like the door wasnt closed correctly after re-checking the door was closed correct and the window closed I could still hear the outside road noise a lot more than in the driving seat.
Has anybody experianced this or can anyone advise me on this one as its got me lost.
Regards Ste Sleds
Post #187393 Tue Sep 09 2008 5:24pm
Josh
Was the window fully closed. I once had a problem with the FNS window not closing properly into the seal which caused a lot of noise. Couldn't see any gap from inside the vehicle. Trip to the dealer fixed it. TDV6 - gone
TDV8 - gone
Post #187394 Tue Sep 09 2008 5:28pm
Ste Sleds
Hi
Thanks for the reply
I thought the window was closed but will have a better look and check it closed correctly.
Post #187395 Tue Sep 09 2008 5:34pm
Tim in Scotland
Also check that one of the back windows hasn't dropped a couple of millimeters, I have found that having one of them open a crack can cause an amazing amount of noise and it it is very easy to accidentally operate the back ones when you mean to operate the front windows 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #187396 Tue Sep 09 2008 5:37pm
Ste Sleds
Thanks for that also Tim.
Keep any suggestions coming, More the merry.
Post #187397 Tue Sep 09 2008 5:40pm
Steve in germany
Get back in the right seat Laughing Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #187403 Tue Sep 09 2008 5:49pm
Ste Sleds
It is for all of you in Germany.
Post #187405 Tue Sep 09 2008 5:53pm
Steve in germany
My steering wheel on my car is on the right side Speed Limits! not where I live!
Back in a D3
Post #187407 Tue Sep 09 2008 5:55pm
Ste Sleds
My mistake
Post #187408 Tue Sep 09 2008 5:57pm
neild.rae
I had a similar problem and found the seal at the top/back of the passenger window was getting twisted into the channel when the window was raised. Almost impossible to see from the outside but it generated a lot of wind noise. Lowered the window, had the missus hold the seal out the way and raised window (her fingers were better in there than mine). Needs to be left closed for a couple of days to remove the twist from the rubber. Neil
Post #187815 Fri Sep 12 2008 1:25am
Ste Sleds
Hi
Thanks for the information will give that ago and hope it works.
RRgards Ste.
Post #187872 Fri Sep 12 2008 9:15am
Also check that the trim on the bottom/outside of the door isn't loose. 2005 Zambezi TDV6 - Gone but not forgotten
Post #187936 Fri Sep 12 2008 11:27am
