![]() | Home > Off Roading & Green Laning > Non-winch Mantec plate for the RRS ??? |
Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194 ![]() ![]() |
I’m thinking of to “butching up” the sport a little, as I’m now tired of the “street look”. So the 20” Stormers are coming off again & am currently trying to source a mild, but yet knotty tyre for the 19” rims. But that’s being discussed elsewhere.
Rupert - not sure. As far as I know they only do the non-winch but ISTBC. Ring Mantec. 2005 Zambezi TDV6 - Gone but not forgotten
RRS G4 Accessory Kit |
Yep, here on the LR GB Website:
2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
Cheers Tim |
bcp Member Since: 11 Oct 2005 Location: East of Scotland Posts: 67 ![]() |
I have 4 of the black 19" 6 spoke alloys if you are looking for rims.
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 ![]() ![]() ![]() |
Rupert,
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Also, I don't know where the intercooler air vent would be on a turbodiesel engine (on the S/C it's be down there behind the LR G4 accessory skid plate), so you may have to modify that plate a bit as well. Here is a rr.net forum member with a S/C and the plate, note the holes drilled on the LH of the plate to allow for airflow to the supercharger:
Thanks so much guys for your advice |
These sort of cuts are normally one-way... a little bit like fitting the roof bars. |
Yes Shmoogy I'm sure the cuts are indeed one way |
As long as the underbody shield is on, you cannot see the cuts unless you peer very closely around the recovery hook. If you are planning on taking the shield off, then the cuts would be visible, but perhaps you could then replace that plastic piece with a new one. PJPR
Michaels RRS Member Since: 02 Mar 2007 Location: North Yorkshire Posts: 63 ![]() ![]() ![]() |
Is it not possible to grind off the two plates shown in the photo below, then you would not have to trim the bodywork to fit the guard ? and when it time to sell the RRS, just refit the tow hook cover |
Wouldn't that also weaken the plate in its most vulnerable strike zone, though? ![]() |
