Home > General > Heated washer fluid
caporajm
United States 2006 Range Rover Sport Supercharged Vesuvius Orange
Heated washer fluid
Is it true that the RRS has heated washer fluid? I tried spraying it to deice my windsheld, and I don't think it worked very well. Can anyone help with this? RRS S/C Special Edition, Vesuvius
Post #9875 Tue Jan 10 2006 9:19am
grommet
United States
Not exactly "washer fluid." From the manual:
Heated washer jets
If the ambient temperature falls to a point where icing of the washer jets could occur, power is applied to heat the jets provided that the starter switch is in position II.
An approved windshield wash is necessary to prevent freezing in very cold weather.
Basically, the washer jet tip is heated when necessary so they do not stay frozen. It's your job to use washer fluid with anti-freeze protection.
Post #9877 Tue Jan 10 2006 9:33am
Not to mention the fact that the heated windscreen works fantastically well for performing the deice first thing in the morning when you get out to the car.... hit the PROG button as soon as you get in the car and the front and rear screens will be clear within a couple of mins, sometimes quicker if you help the ice away with the wipers.
Post #9879 Tue Jan 10 2006 9:55am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
And don't try and cheat by pouring hot or boiling water on a frozen screen otherwise....
 L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #9944 Tue Jan 10 2006 3:52pm
