Home > Maintenance & Modifications > Suspension Fault warning indicator |
If you search these forums for that message you'll find several posts talking about it. With some folks it comes and goes, with others it has actually led to the suspension going kapooey. It's probably nothing if this is the first time it's happened to you, but be on the lookout for it occurring multiple times and report it to your dealer if so. You don't want to be stuck with no suspension...
Thu Jan 05 2006 10:38am |
As schmoogle says - probably not a real problem To fix switch engine off, take key out of ignition, lock the car, unlock the car, restart the car - problem should be fixed. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Jan 05 2006 10:54am |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
My cars in at the dealer as we speak, had this message a million times ( plus others ) it turns out nothing wrong with suspension/transmission etc , but error message due to extremely bad battery ( most of the cells were dead )
Fri Jan 06 2006 9:48am |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
Oh ! after reading of others suspension faults numerous times in the last 12 months (on D3 and RRS forum) I have now had the problem occur on my almost new RRS. Less than 1,000 miles and tonight on the way home the red suspension light comes on together with a series of warning messages (special programs off, maximum speed 30mph, suspension raising slowley - or something like those). The usual turn off, count to 10 and turn back on again, didn't clear it. It felt as if the suspension stopped working altoghether with a very hard, undamped and pogo like ride. I drove home a few miles very slowley. Expected the car to be down on its bump stops when I got out but infact if anything it appeared higher than normal. Should I expect everything to work tomorrow morning or is this a job for International Rescue (aka Land Rover Assist) ? |
Tue Jan 10 2006 10:31pm |
RZARVRSPRT S/C Member Since: 05 Jan 2006 Location: LOS ANGELES, CA Posts: 11 |
My warning light cleared the next day but i only had the orange warning light go on.....If you had the red warning light go on with all those messages I would definitly take it in just to make sure....good luck!!!! '06 RRS SC BLACK ON BLACK ON BLACK 22' HRE'S |
Wed Jan 11 2006 2:01am |
This is what happened to mine, it turned out to be a faulty battery. All fixed and now working fine. I put up with the warnings ( which would come and go ) for some time .... but it got worse and worse. It would appear that all the "special" systems in the sport are very sensitive and any drop in amperage/voltage would alert the sports computer to thinking there was a problem with the particular part/operation and shut it down. It should'nt happen - so get it checked immediately " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Wed Jan 11 2006 9:23am |
Well today I had the horror of seeing my brand spanking new RRS "uplifted" to the dealer. In other words a nasty big recovery truck slung my lovely shiny RRS onto its back and rumbled off with her. I am now a Ford Focus driver
Wed Jan 11 2006 9:48pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2581 |
A new gearbox is A LOT more serious than an electrical/comms issue. I'm sure your's will be sorted soon. Keep the Faith. L319 D4 HSE
Wed Jan 11 2006 10:24pm |
Saga update Friday 13th Jan. Dealer rang yesterday to say it was one of the rear height sensors at fault. They hadn't got one in stock but said they had it on overnight delivery and it would be fitted first thing Friday and the vehicle returned to me for the weekend. As a result we stick with our plans to take off for the weekend to friends in Bamburgh.
Fri Jan 13 2006 9:05pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Smarticus, in fairness to the dealer, it WAS Friday 13th after all... Sorry to hear that. |
Fri Jan 13 2006 9:19pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
heard all this before.... latest quote from dealer is that suspension and gearbox sense when trailor is plugged in and adapt... when you unplug the tailor was when my warnings were being triggered, gearbox faults were also blamed on software......then break in engine/bpx loom which involved taking the car interior to bits at two weeks old... then a faulty box and finally when the box started to slip at low revs and vibrate at higher revs... another faulty box..... 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Jan 15 2006 8:26pm |
This happened to me ( different part though ) its just not good enough. " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Mon Jan 16 2006 1:33pm |
