Home > My Range Rover Sport > My "detailed" Sport.
RonnieG
npinks wrote:
RonnieG wrote:
npinks wrote:
Looks nice Ronnie Thumbs Up Thumbs Up
I wish I had the know how to paint correction the car for the same finish.
Might just buy a g220 and a scrap panel and play around
With the G220 you can't go too wrong I would work away! just start out with applying LSP and the progress from there
The plan is to get it spotlessly clean and polish with AG SRP or AG EDG, then put on 2 or 3 layers of collinite 476
Would you recommend using a G220 on SRP or EDG to either apply or buff off at my level of expertise? or do it by hand
also is a G220 ok for Collinite 476 apply thin layer by hand (applicator sponge) and then using it to buff off layers?
I would use the G220 for applying the SRP the only problem with this is it has fillers so you are not going to get true correction and after a short while, the marks will reappear. Personall I don't like the AG products. I would personally go to Tim at Clean your Car and get the sample Menzerma range for £29 and use it start with the lightest cut with a finishing pad then step up if this does not work. I would finish with a couple of coats of Collies by sponge applicator wipe with some megs QD and then sit back and admire!
As My final wax I used Dodo Juice Double with 2 coats of hard wax and 2 coats of soft wax then wiped down with Zaino Za to remove any hazing.
Post #171687 Thu Jun 05 2008 11:45am
Just to be clear in my head would i use the G220 to wipe off the collies or use my elbow grease and mircrofibres with QD.
Which pads do you use, or can recommend, for applying SRP (do i need a pad for taking off srp too Embarassed )
This level of polishing is totally new to me Embarassed but been fancing getting a G220 as the results are amazing when used correctly Thumbs Up
Post #171691 Thu Jun 05 2008 12:44pm
RonnieG
I use 3m compounding and finishing pads (6") and sonus 4" pads. You will use a microfiber fo wipe off the collies then give it a go to get rid of any hazing form excess wax. PM me and I will give u my mob number if u want a chat. Also have a read of some of Dave KG's how to tips they are very good.
Post #171717 Thu Jun 05 2008 6:32pm
cheers for the advice there Ronnie
Got to spend my money on one of two things then i'll get the g220 bought with some sonus 4" & 6" pads and lots of 3m tape
Then give the car a good going over, I'll PM when i get to this point, until i have a g220 i sort of know what i'm doing it hink anyway Laughing
Thanks again for the advice
Post #171718 Thu Jun 05 2008 6:49pm
Ronnie - top marks on the detailing Bow down Bow down Bow down Bow down
Post #171722 Thu Jun 05 2008 7:16pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Amazing!! Thumbs Up Thumbs Up
I would not have the patience for all that flaffing.....as a lazy g1t, I would simply pay someone. Rolling Eyes , it probably would not look half as good, but hey, 34 hrs is almost a working week Shocked L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #171737 Thu Jun 05 2008 10:09pm
More like 2 weeks mate RRS TDV6 Gone but still around
Post #171743 Thu Jun 05 2008 11:02pm
will_wonka
Rolling with laughter L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #171745 Thu Jun 05 2008 11:22pm
