Home > Site News & Feedback > Rangerovers.net's forum is down
shmoogle wrote:
It could be this isn't actually an issue in MySQL, but more an issue in the PHP database connection logic. Theory says create a connection to the db, operate across it, close it and thus release resources back to the pool. If the PHP MySQL libraries or the code in phpBB that calls them isn't managing the connections properly, the database resources simply get chewed up and never released. I'm not a MySQL expert but in application development generally, persistent connections are normally set for performance reasons (i.e. to increase performance of apps that have high, constant database use where the creation of connections has an impact on response) but this brings with it it's own set of caveats... so only allow them if you're aware of the consequences Very Happy
S - your right, however the guys who developed phpbb3 require modifications to the mysql config and they just say the server host needs to change it at their end - once changed, phpbb3 works perfectly
Post #171604 Wed Jun 04 2008 6:46pm
Fair enough mate... just throwing in my 2p, you'd know more about phpBB than me Thumbs Up
Post #171651 Thu Jun 05 2008 8:16am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
We're back across the pond... But the owner of rr.net may be forced to look into a different host, or at least a new hosting plan, as the fix is only temporary. Keep that in mind if you ever go w/ v.3, Martin.
Post #171750 Fri Jun 06 2008 12:30am
Umber - that does seem to be the common result for many people moving from v.2 to v.3
glad your back up, even temporarily
Post #171762 Fri Jun 06 2008 7:35am
Nice work, Umberto... let's hope the permanent "fix" doesn't take too long to sort Thumbs Up
Post #171770 Fri Jun 06 2008 9:43am
Martin
Site Administrator & Owner
RRSPORT (and the other sites) are already on a dedicated server over which I have full control, instant access and very, very, very good technical support Thumbs Up Like this site? Buy some RRSPORT goodies to show your support!
Post #171812 Fri Jun 06 2008 12:03pm
RRSport is by far a superior site both technically and as a source of information. 2005 Zambezi TDV6 - Gone but not forgotten
Post #171814 Fri Jun 06 2008 12:19pm
I'll second that VA Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #171816 Fri Jun 06 2008 12:33pm
Bow down Thumbs Up Bow down Thumbs Up Bow down Thumbs Up
Post #171829 Fri Jun 06 2008 12:53pm
