![]() | Home > Technical > Transmission Noise - TDV8 |
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 ![]() ![]() ![]() |
Hey James, yeap thats mine... I know your guys are working hard to get it sorted ![]() My gripe is with Land Rover ![]() ![]() BMW R1200GSA Rallye GONE** Fiesta ST2 - Mrs Wokka's - AMG35 now GONE**BMW K1600GTLE Matt Blue GONE**Disco 4 2014 Firenze Red GONE**Evoque SD4 Dynamic Coupe GONE**RRS 5.0 SC GONE**RRS HSE TDV8 GONE**RRS HSE TDV8 (The Crap one) GONE**FL Facelift GONE**FL 1 GONE**D1 GONE**BMW R1200GS Adventure GONE: Kawasaki ZX10R GONE: Focus ST2 ** Chinook CH47 - 2 x T55 engines 3,750 hp each!! 183mph, 2xM134 Miniguns, 1xM60 |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Does it sound like that discussed in http://www.rrsport.co.uk/forum/topic2725.html? I have this noise and it sh*ts me to tears! They have replaced my T case but it did not get rid of the problem. I have been told it is the chain drive in the transmission...it does not have a tensioner and when you back off you get chain rasp. ![]() ![]() |
mine also had the wine when it went in for its first service, found that the front diff had leaked all its oil out so replaced the diff, and noise went away. Just a shame I cant drive it now, the car is somewhat taken to bits to replace a turbo that has quit boosting............. boll**, no option to post a photo....body in air, chassis on floor. Not pritty.. |
Good news the Transfer box has cured the problem |
Good news mate... nicely done |
Japseroony Member Since: 06 Feb 2008 Location: At home with a beer!!! Posts: 256 ![]() ![]() ![]() |
Will have to get mine back in now to see if they can find out if its the same |
its back |
Well mine is at long last with the stealers and they have said its the transmission box that is at fault so are ordering a new one - possibly up to a week for it to arrive |
Well what a complete f |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
The noise will only have reduced because of the new oil and the fact that it probably hadn't heated up again fully when they tried it.Surely if the old oil was black, this in itself indicates that there is a problem (causing excessive heat build up) within the box, and LR should not ignore that fact,( I'm sure they all think we were born on 30/07/2008 |
Oh believe me when I explaind what you have said to the dealer, they were somewhat embarassed as clearly they just expected me to take the vehicle away ![]() ![]() Either the oil was the incorrect type from new causing it to overheat, which in its self would cause damage to the box or the box has a fault causing the oil to go black ![]() ![]() After my explaining the facts to them they agreed and even said that the techincian had said that he did not think it would cure the problem, which begs the question - why did they not go back to LR for further comment or are LR just begining to wake up to the fact that most of the newer RRS might have a transmission problem and are trying to fend off the issue ![]() "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Well things just get better and better or should that be worse and worse ![]() ![]() LR have just called me and said they have given permission to replace the transfer box - not the transmission. Correct me if I am wrong but these are two seperate components aren't they with one being the actual gearbox and the other the transfer box ![]() The stealer has now said that they replaced the oil in the transfer box and not the tranmission as they insisted yesterday ![]() Is this some intervention from LR to replace the transfer box (a much cheaper item than the transmission) and not the transmission ![]() I will be listening for any kind of noise when I get it back and making big noises at LR if there is a slight squeak ![]() ![]() "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Still at the f |
pers1 Member Since: 22 May 2006 Location: Heggedal Posts: 35 ![]() ![]() |
I have the same noise most noticable at 2000rpm and in sport Mode. I had this noise since it was new!
