Home > General > ACE Pump removal or bypass, help needed
ZAX1
United Kingdom 2009 Range Rover Sport TDV6 HSE Java Black
Hi,
I have issues with the anti roll bar, leak ,
currently popped 2 ACE Pumps and belts as I had the dreaded noise of a failed pump, lots of play in the pump pulley,
I not sure where the issue is but as I don't really need this feature, I am looking to bypass the ACE pump.
I have seen that you can just use a shorter belt which I have done, however I can't seem to see the diagram to bypass the pump, if anyone can help.
Failing that, I could remove the pump and does anyone know if I can just replace the space with a same sized pulley so that I can just run without the pump, but of course there will be a pullery spinning in its place.
All help is appreciated. thanks in advance!
HSE Sport 2.7 TDV6 2009
Post #641057 Tue Apr 09 2024 8:38pm
https://www.rrsport.co.uk/forum/topic58466...ce+removal
Post #641102 Thu Apr 11 2024 8:59am
